Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      DG,
      Thanks for the testing & report.
      I had a quick look at the logs and I don't see any particular issues.  The vibration levels (see VIBE message) are pretty average.  X-axis is higher than the other two (normally Z is the highest) but in any case, the levels are not terrible.
      3702576975?profile=originalAs you suspected, the vehicle entered RTL while it was in Guided mode probably because the connection to the tablet failed.  I would have expected Tower to cry out "lost connection with vehicle" but that's really up to the GCS developers.  Although the vehicle would have updated it's status to "CRITICAL" and sent that to the GCS, with the telemetry link down, it would not have gotten through.
      The vehicle does seem to climb from 4m to 10m at the beginning of the RTL.  I suspect if it was given a bit more time it would have completed the regular RTL cycle.  There's no record of the vehicle attempting to go into RTL a second time.  It looks like you're not using ch5 flight mode switch to control modes, so perhaps it was switched using Tower?  in which case, with the telemetry link down, that wouldn't work of course.
      3702577197?profile=originalThe voltage and current recorded in the logs appears reasonable with the voltage dropping slowly from about 16.6V to 14.8V during the flight.  The current seems strongly correlated with the throttle output and is at a reasonable 20apms most of the time.
  • This reply was deleted.
      @Heddn,
      I think the reason for you crash is the same as why people were crashing with -rc6.  Master does not yet include the patch that resolved the attitude issues found in -rc6 because the fix affects plane and rover so I need to get the plane/rover guys agreement first (Tridge and Grant).  Hopefully we can get that into master soon, until then, stick with -rc7!
      • T3
        Randy,
        I thought that this patch solved it:
        https://github.com/diydrones/ardupilot/commit/686b1137fa18713124868...
        Maybe he just missed it...
      • I think rc7 is a best firmware to the date. I will try to play with my hex tomorrow.
        Quad i played with today, and i could not make any control combination input to make it do anything wrong.
        Only issue i see is still with gps glitches when drone reaches the ground, it sometimes starts reajusting rtl position inches away from the soil, catches ground by its landing gear and flips. I think it is due to an error in baro readings or gps data - i noted sometimes altitude reading goes totall wrong saying, like, 3m altitude when i lower it down to just under 1m height, but it is hardware. Unless we get good reliable sonar there is probably little to nothing that can be done to make drone know it is inches away from the surface.
        Yet this issue happened only once. All other functions were great. Lift off is straight and smooth. No wandering about after lift off. I got it 100m into air, swapped to simple mode, flew all 6 modes, it landed back in rtl 30cm away from take off spot.
        Gps super simple mode still sometimes flips controls but as i stopped using it - simple mode seems to work just fine. Ma be super smle mode is not even worth keeping if it is impossible to prevent controls direction invert at close range.
        My 9yr old son flew it too, and is absolutely blown away. :)
        May be there is something bad in there. But compared to positive things i think it is a best firmware to the date. I crashed once in rtl as drone started readjusting position close to ground and got caught by landing gear but i think it is hardware, plus, it only happened once. I wish i had more time to help write this, but, so far it looks to be a truly great code. It is way better than old 3.2 and response to controls is really nice.
        I will try to link it with new banggood 3d storm32 gimbal, will see how that goes.
    • Something magnetic nearby perhaps. I have magnetic tool holders on the wall by my workbench and if I place my quad to close, I get the same errors. Actually anything magnetic in proximity will cause that error.
      • I find sometimes MP does not report the offsets until you refresh the parameters.
  • I flown my quad with Rc6 last saturday, everything seemed to be ok, except for the landing, my quad almost tilted upon triggering land. :)
    by the way, which version of mission planner can you recommend, the official update or the beta update?
    • same here, as soon as I read that note, I updated to rc7.but still havent tested it yet
    • Note on the first page:
      http://diydrones.com/forum/topics/copter-3-3-beta-testing
      FW5OxQg.pngI am using rc7, very cautiously.
      • I did a couple of long flights with rc7 this evening. Everything seemed fine. No different to rc5 that I could tell. Was a little windy and it held position well.
