Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Well remember that you have to do rc calibration, so any changes you make in the radio propagate down the line. I for example change the servo limits and pitch direction in my radio, everything is default on the parameters in APM. This lets me swap a radio if need, since nothing changes on the pixhawk, only on the radios (if there is a channel that needs reversing on one radio but not the other).
We've added a tricopter setup wiki page. It's a bit sparse at the moment, it only lists the parameters that have changed since AC3.2.1. We can build it out further if people would like and can provide text to add (if you're really keen Hamish can add you to the wiki editors group or you can simply add a to-do item with text to the wiki issues list).
Some kind of video of a tricopter flying Copter-3.3 (or 3.2.1) would be a nice addition.
I've also added an item to the release notes so we remember to warn people when AC3.3 goes out officially.
@SwissFreek,
Thanks for testing & reporting. I guess Johnex has pointed out the change that we forgot to include in the ReleaseNotes.txt. It went in as a "clean up" as part of the RCMAP changes but we should have documented it better. Sorry about that.
So as Johnex says, the TriCopter setup procedure is different now because we've separate the yaw servo's min, max, trim and rev parameters from the ch7 input parameters.
I think your servo should work if you set MOT_YAW_SV_REV to -1 or +1.
Johnex, have you got your tricopter working on -rc7?
full parameters list -> RC7 out -> rev change the number to -1.
done.
hm.... something weird...
will try to test tonight......
nope, talking about different thing. full parameters list -> RC7 output ->rev -> -1/1
been flying tricopters with AC code long enough to tell it works very good, the only thing which didn't ever work for me properly is autotune. it worked OK up to 3.1.5, later revisions changed it to absolutely useless. tried on RCE and my own 6s powered tri.
It was actually 0 and 1 until randy changed it, which made more sense from the name of the parameter YAW_SV_REV(erse) "true" 1, "false" 0, i missed the later commit where he did -1 and 1.
What GCS are you using? Have you tried a different one? I would think more copter would be having problems with such a basic setting. Maybe it is the GCS that isn't properly doing what you expect. I noticed in a quick Google search that something similar had been a problem before. Just a thought...
Yeah, try setting YAW_SV_REV to 1. Now there is also YAW_SV_MIN, YAW_SV_TRIM, and YAW_SV_MAX for min, center and max PWM output to the servo as well.
You might have to do a forced parameter update in Mission Planner.
Ctrl + F and click ParamGen.
285
286
287
288
289
of 449 Next
