Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • i just had a bad autotune with 3.3-rc7 on a t960 with 18" props and 288kv motors on 6s. Autotune completed ok, but when I went to take off with the new PIDs, it shook violently as soon as it got in the air so I put it straight back down.
    It flew more or less OK with the 'before' PIDs, but was wobbling a bit in a 30km/h wind the other day so I wanted to see if I could get it to fly smoother.
    Param      Before        After
    rate pitch P 0.3    0.49
    rate roll P 0.3       0.47
    rate pitch D 0.01   0.026
    rate roll D 0.01      0.026
    stab P 5              13.1
    rate yaw P 0.3      2.0
    stab yaw p 4         7.6
    Autotune aggr was set to 0.1
    the mot_thst and battery scaling params had also been set for large props and 6s before this.
    The log is 80mb, but it's here if you want to take a look at it Leonard?
    Dropbox - Error
    Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
      Hi Glenn Henri and Erik,
      How is it all going. Sorry for the delay getting back!!!
      Looks like you have all got it worked out. Let me know if you have any questions needing answering.
    • T3
      Glenn,
      the vibes are relatively high as are the IMU2 Acc values. Hence, it might be a vibration issue.
      Best regards,
      Thorsten
    • +1 EXACTLY same behavior with same aircraft!
      (Autotune completed ok, but when I went to take off with the new PIDs, it shook violently as soon as it got in the air so I put it straight back down.)
      leonardthal was very helpful and mention that before autotune we should set aggr to 0.05 AND:
      MOT_THST_BAT_MAX, number of cells x 4.2 ==>
      4 cells = 16.8
      5 cells = 21
      6 cells = 25.2
      8 cells = 33.6
      MOT_THST_BAT_MIN, number of cells x 3.5 ==>
      4 cells = 14
      5 cells = 17.5
      6 cells = 21
      8 cells = 28
      MOT_THST_EXPO 0.75 (for 18 inches props)
      and
      THR_MID,300
      So the "violent shook" should not occur IF we start with standard parameter and set the above prior autotune.
      Doing one axis at a time is wise as it might take too long for a single battery to do the 3 Axis.
      (Autotune Bitmask: 0:Roll,1:Pitch,2:Yaw
      VALUE MEANING
      7 All
      1 Roll Only
      2 Pitch Only
      4 Yaw Only
      3 Roll and Pitch
      5 Roll and Yaw
      6 Pitch and Yaw
      As for being too crisp after an autotune
      You have 4 parameters you can use to control how crisp it feels.
      RC_FEEL_RP
      ATC_ACCEL_P_MAX
      ATC_ACCEL_R_MAX
      ATC_ACCEL_Y_MAX
      If you find it too crips, just reduce ACCEL parameter for the axis you want to make more gentle.
      Hope this helps (all the above were in this thread documented by leonardthal  but 189 pages is a bit long to find relevant info)
      Henri
      • Thanks for that, what PIDs are you now running with this same craft? Does it fly well in strong wind? I did set the MOT_THST_EXPO and MOT_THST_BAT_MAX params to the suggested values already, just not the aggr.
        • Yes the if aggr is 0.1 that could be fine for very small 450 or 500 size quad but far too  nervous for medium size aircraft such as T960 T1000 or larger T18!
          When I had the same "impossible to fly" attitude, I did manually "tame it down" as I needed to fly this photo shoot using the Sony NEX5R. after many many attempts, it finally decided to behave differently than a mosquito on steroids! Not the best thing to do but...
          Still need to "re do" the autotune 3 axis one by one.
          The 18 inches T-propellers were really worth the extra dollars compared to the el-chippy H.K. pretend CF ones!
          Anyway it did hold beautifully in wind at 35 meters altitude had a 25 to 30 degrees slant against wind. The grid mission completed perfectly and it landed perfectly as written in mission planner. Thanks to the NEO-M8N precision NeoM8N and HMC5983 compass
          Had another issue with simple bgc 32 bit gimbal controller but that is not related directly to 3.3 testing.
          Really worth the effort (3.3 rc7) :-) Thanks to all the developers.
          Henri
          • Hi Henri,
            Indeed I have seen the same, it's holding position pretty well with the NeoM8N and counteracts wind influences when needed, which brings back the trust level big time...
            If you can depend on the statement "it will stay up there no matter what wind speed you through at it" you flight expirence is much more relaxed, than it was before..
            Now this EKF guy needs to be getting under control, so you can reliably run long auto missions and I will be very happy.
            I do see some accumulated clipping in the Vibr part of the log during 600m Auto controlled trips, due to wind influence, as in hover I am not expiriencing any vibration at all.
            The uncertainty that the EKF error might step in any time along the flight path, and kick in a LAND command (while the drone might be out of sight) is horrifying.
            Just the search action you will need to undertake to find it back....
            But I am sure the Devs will find a solution, and make it even more reliable as it already is !
            Erik
        • oops
