Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • I´ve the teensy working with -rc8
  • Hello Folks,
    since -rc8 was released I´m using it. I´m flying every Day min. 1h. No faults every thing worked very good.
    Only on thing does not response is the "DO_CHANGE_SPEED" command. Just nothing happens! But I´ve to say that I´m using ch6 to change the WP_Speed. My thought is the the DO_CHANGE_SPEED command overrides the WP_Speed and if a new WP_SPEED comes from ch6 it overrides the previus command.
    I would appreciate a "condition_change_speed" AND a "condition_change_VS" (VS=vertical_speed).
      Andre.
      Yes, as you suspect using ch6 to "tune" the wp-speed will overwrite the do-change-speed command.
      There are a couple of to-do items (here, here) on the issues list to allow setting the speed-up/dn but just haven't gotten to it yet.
  • Hi
    My pixhawk accel calibrates fine on 3.2 but refuses on 3.3rc8.  Could this be linked to the acceleration sensitivity being increased?
    Gareth
    • Anyone able to advise on this?
  • Just thought I'd give a shout out to the Dev's of 3.3!  A solid day (so freakin' tired!) of mapping for contours and volumetrics.  My mapping X8 is solid as a rock.  25kph winds and going strait as an arrow.  Still a few issues with the geotagging, but not a bit problem using Pix4d and a 90 degree kappa adjustment.  Best flying mapping drone yet.
  • I have not been able to download log files via Mavlink or even terminal IIRC since day one on PIxhawk. It always pops up "Error receiving log list". I have gotten so used to pulling the sd card out and getting the logs it kind of became normal. Would erasing the sd card and reloading the firmware fix it?
    • I see this when there are too many log files on the card (>50?). You might want to try removing some if this is your issue.
      • Well it does have over 400 log files :)  Guess that makes me a log hoarder.
        But the AUAV-X2 has over 200 and works fine.
        Seems like the Pixhawk has always had trouble pulling logs via MP though. I may format the SD card and reload, but will first clear out the log files.
  • Hello~~
    Are IMU::AccX and ACC1::AccX in the same scale?
    I flown rc7 two times. The first flight has Raw-IMU logging off. LOG_BITMASK = 0x173FF8. For checking vibration I plot IMU::AccX/Y/Z and it is shown below.
    3702059573?profile=original
    Then in the second flight I turn on Raw-IMU logging. LOG_BITMASK = 0x0E7FFF. But then in the dataflash data file "IMU" records no longer exist. But there is a lot of ACC1::AccX/Y/Z records. So never-mind I plot them out and check for vibration. But the vibration becomes very large.
    3702059611?profile=original
    I didn't change any hardware between two flights. Does the vibration really go that worse in the 2nd flight or it is just because ACC1 and IMU show AccX/Y/Z in different scale?
    Another question. I always see the error code FLIGHT_MODE-15 in my dataflash data. What does the sub-error-code "15" mean?
    Thank you~
    Wilson
