Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hi Leonard,
I hope you're referring to the first log I posted and not the second one. I thought that one was good. Let me know if I'm wrong!
Hi Shaun,
Yep, that is much better!!! Sorry I didn't see the rest of that thread and came in late.
Shaun,
Using the new VIBE message it looks like the vibes are a bit high including clipping. I haven't looked super deeply into the logs to see if it's something else but this alone could explain the behaviour.
So to any of those Pixhack users, the internal damping is not so good. Here's the difference after adding a cheap Hobby King damper. Looks good enough? No clipping. Z axis is below 30 now instead of around 100.
2015-08-16 15-45-16.bin
Yes, much better. I hope the word gets out to Pixhack users and back to the manufacturer that the internal vibe dampening is not sufficient on many frames. Maybe with the improved Vibe reporting in AC3.3 the manufacturer can do a better job on a future revision.
I'll give the group a heads up. I had posted it was pretty good previously so I should let them know. Retesting everything now. My hex version of this frame isn't so good either (Pixhawk with 3DR foam), no clipping though. I've got 5 more of those mounts and 4 more copters to test : ) Thanks again for your help.
So we don't use the pull down menu "vibration" anymore? Doing that my vibes look good lol. This looks really bad. Over 80m/ss and clipping looks bad (don't really know what to look for in the clipping graph). I presume clipping shouldn't keep escalating like that. Wow, my missions are usually 30 to 40 min, I'm thinking I'll be running into some trouble.
Strange. These two copters are almost identical. Both running 3.3rc8, 5010 288kv motors, same props... Only difference is the two extra motors on the X8 and the fact the X8 is using a pixhack and the Hex is using a pixhawk. Both have more than sufficient power : )
Have the same problem with my X8 (330kv motors, 16" propellers)
84.BIN
212
213
214
215
216
of 449 Next
