Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • Also - I'm curious, what specifically do you find is not working about ROI?
      • Turned out that the problem with ROI is the Andropilot app for Android I was using. It erases the ROI point from the mission as soon as it is loaded by the app! Switching to Tower.
    • Hi Arni, yes, I have had a 3 or more cases where the landing detection failed and yaw left killed some props. Bummer. For now the solution is to be very careful when landing... I find when I land steadily, I have no issue landing in GPS assist modes such as Loiter.
      Also, the one time I had the presence of mind to "catch" it while it was flipping, I jumped to Stabilize and throttle at minimum was enough to minimize the damage (one prop that time).
      Long term solution as far as I know is tight integration with range finder sensors. Some also have a motor kill switch but I feel that is a safety issue as accidentally hitting that in the air would not be cool... switching to Stabilize at min throttle does effectively the same thing.
    • the log...
      2015-09-12 15-44-50.bin
  • I'm not sure this is a 3.3-rc11 issue but I just updated from 3.3-rc9 to 3.3-rc11 after changing my ESC's. When I arm the quad the motors do not start to slowly spin. I have recalibrated the TX, and the ESC's twice. I had to raise MOT_SPIN_ARMED up to 144 to get the motors to slowly spin upon arming. I went from ZTW w/SimonK to the Hobbywing Xrotor ESCs. I use these same HW xrotors on a hexa (w/different motors) running 3.2.1 that works fine with MOT_SPIN_ARMED set at 70.
    Has something changed with firmware that would cause this? Should I be worried about flying like this?
    • Just wanted to report that two more ESC calibrations solved the problem. Not sure if something now differs from what the wiki says but I just waited longer in between tones on last try and that did it. Set MOT_SPIN_ARMED at 70 and all is fine.
      • seems weird, Shawn. It would be interesting to have a report of ESC calibration available somewhere, maybe on the RC Calbration or Motor Test screen, to see what 'stuck'. What do you think it was that made the difference, just the wait (if so, maybe we need to enforce that in the code)?
        • I think it was just the wait difference. I also think the tone sequence(s) have changed compared to the wiki but I didn't do it over and over to verify. What is weird is that it appeared to have calibrated all of the times previous to the last because the throttle/motor response seemed the same. I believe another post said something about the tone sequence too.
  • This reply was deleted.
    • Niether of my Lites have "that" issue but both get BAD AHRS on bootup. Sigh. It eventually clears though.
      I WAS getting that error though and it was odd because I was just using the internal compass and no external which makes me wonder how it could have a bad variance. I flashed back to 3.1.5 and did a console erase and reset and then flashed 3.3-rc10 and that part went away.
    • I have one of those, and running fine.
      Calibrate mag as instructed on the wiki.
      On my small 330 Quadcopter that I've been using to test 3.3 the ESCs are right below the PixHawk lite so I added a small aluminum self adhesive foil below the PixHawk. Note the small post for the GPS+Mag (a BG880 unit).
      The mags are reporting some sensitivity, and at 2 meters from my car the Compass Variance would go nuts, affected by the large metallic mass....3702593867?profile=original3702593665?profile=original3702593750?profile=original
