Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
After the second mission I could not get a rearm at all even after several minutes.
MP only showed a "Disarmed" message on screen.
I will have to wait until this evening to review the logs.
I was wondering it this had happened to others as well.
I'm trying to track down some compass issues on a AUAV-X2. If I disconnect the external compass on rc12, COMPASS_EXTERNAL still always says "1" after I reboot. I tried setting manually and it always gets reset. This is supposed to be autodetected on a pixhawk - anyone else see this behaviour? The compass IDs also do no get reset - are these determined at calibration time or on boot? I had assumed boot, but maybe its only calibration?
What are COMPASS_EXTERN2 and COMPASS_EXTERN3?
Different question. If I calibrate the internal compass on its own I get offsets of (52, -104, 327), if I calibrate them together I get (-15, -32, 127). How can this be? I would expect the values to be close-ish, but they are miles apart!
Both times I had a good set of data points and the output is relatively stable if I rerun the calibration.
Or is this more a mission planner question?
Andy,
I agree with you that there shouldn't be any difference to the compass calibration results depending upon how the compasses are calibrated (how many, in what order, etc).
.. and as you guessed, it's more of a mission planner question I think. The compass calibration logic is completely within the mission planner. For Copter-3.4 the calibration will be moved to the vehicle (it's already in master).
that is apparently a support for multiple redundant compasses that would be awesome if it worked - but as all external compasses units in the gps receivers sit on same hardware address nothing of that works.
I am still on rc10 but if I disconnect gps with external compass it for sure sets compass external parameter to 0.
Never mind - I had pulled the GPS cable so the compass was connected but not powered (I'm guessing).
Disconnecting the compass does result in the external parameter being set to 0.
Popping in here to say that 3.3 rc12 ran great on my IRIS+. Granted I was not able to test every single mode and function but out of the modes I was able to fly in ,AltHold, Sport, PosHold, Circle everything went smooth. First flight no gimbal. took off fine. Got to a good altitude and let AutoTune run. AutoTune complete. Ran tests in AltHold, PosHold, Sport, Circle, Land, all good no issues IRIS+ was 100% spot on. Second flight gimbal attached. Launched fine. tested same flight modes, all good. No issues, IRIS is solid. Had 12sat 1.4hdop on both flights. Had my ground station up and running but I was flying IRIS+ a few feet away so I wasn't see what the HUD was displaying.
I would post my logs but the issue of "Error receiving log list" that other's have run into is prevalent. I have tried some of suggestions that were previously posted but I am still receiving the error....I will continue to try and figure this anomaly out.
Todd H
Oh and thank you to all the testers and programmers. I don't think that can ever be said enough.
Today I test for first time 3.3 rc11, two short flight to test the new controller, with standard params no tune yet and some wind; when I download the logs I find that RTL appears two or tree times but I didn't switched, I was near the copter and no failsafe err appears, I check PWM values and looks well, What can be happened?
2015-09-22 17-22-20.log
2015-09-22 17-39-30.log
Hi Cala,
If you look graph "Battery Issues" from the pull down in the log analyser, you can see strange drops in the VOLT reading (It actually goes negative). VOLT drop whenever there is a spike in THROUT (Maybe a battery issue). It seems that when both THRIN and VOLT goes low you get the RTL. It is very short as it seems that once the VOLT go back to normal so does your flight mode.
What power module are you using? Is it 6S?
I might be wrong but are you sure that you are not reading CURR as VOLT and VOLT as CURR? You volt values seem more like current readings (Goes up and down with THR) and the CURR values look more like battery voltage (Starts high and decreases over time).
When VOLT goes low but THRIN is high you do not seem to get the RTL. I might be wong but it seems to be the only common thing I could see.
I don't think that you are actually getting a voltage drop but you power module is reporting a bogus value.
I think you can change the pins in the config to swap these around.
Also, it seems that the first part of your flight is before the EKF is completely happy.
The latest MP has "ekf VEL tune" in the graph option pull downs. If you look at this you can clearly see when the velocity innovations IVE, IVN, IVD start.
I have been trying two different ways to avoid this:
1: Wait until I can arm with the Fence enabled
2: Arming in Poshold. (I usually take off and land in STAB but use this to check)
I think that either method requires both a good 3D GPS lock but also waits for the EKF to be happy with position and velocity comparisons between the IMU and GPS. Not sure if it is the Gyro's settling or the GPS velocities taking time to match up.
I have also noticed that if I land and take off without disarming the EKF noise is a bit higher. I think it may be due to GPS velocity measurements when the frame is landed (ie motionless) but GPS still registers small position shifts.
This does not seem to cause flight issues but I think it does affect things such as the origin setting. I have been playing it safe by making sure that the EKF is completely happy before taking off. It take a couple of minutes first time round but after that it is almost immeadiate.
Hope that helps!!
