Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I'm trying to track down some compass issues on a AUAV-X2. If I disconnect the external compass on rc12, COMPASS_EXTERNAL still always says "1" after I reboot. I tried setting manually and it always gets reset. This is supposed to be autodetected on a pixhawk - anyone else see this behaviour? The compass IDs also do no get reset - are these determined at calibration time or on boot? I had assumed boot, but maybe its only calibration?
What are COMPASS_EXTERN2 and COMPASS_EXTERN3?
Different question. If I calibrate the internal compass on its own I get offsets of (52, -104, 327), if I calibrate them together I get (-15, -32, 127). How can this be? I would expect the values to be close-ish, but they are miles apart!
Both times I had a good set of data points and the output is relatively stable if I rerun the calibration.
Or is this more a mission planner question?
Andy,
I agree with you that there shouldn't be any difference to the compass calibration results depending upon how the compasses are calibrated (how many, in what order, etc).
.. and as you guessed, it's more of a mission planner question I think. The compass calibration logic is completely within the mission planner. For Copter-3.4 the calibration will be moved to the vehicle (it's already in master).
that is apparently a support for multiple redundant compasses that would be awesome if it worked - but as all external compasses units in the gps receivers sit on same hardware address nothing of that works.
I am still on rc10 but if I disconnect gps with external compass it for sure sets compass external parameter to 0.
Never mind - I had pulled the GPS cable so the compass was connected but not powered (I'm guessing).
Disconnecting the compass does result in the external parameter being set to 0.
Popping in here to say that 3.3 rc12 ran great on my IRIS+. Granted I was not able to test every single mode and function but out of the modes I was able to fly in ,AltHold, Sport, PosHold, Circle everything went smooth. First flight no gimbal. took off fine. Got to a good altitude and let AutoTune run. AutoTune complete. Ran tests in AltHold, PosHold, Sport, Circle, Land, all good no issues IRIS+ was 100% spot on. Second flight gimbal attached. Launched fine. tested same flight modes, all good. No issues, IRIS is solid. Had 12sat 1.4hdop on both flights. Had my ground station up and running but I was flying IRIS+ a few feet away so I wasn't see what the HUD was displaying.
I would post my logs but the issue of "Error receiving log list" that other's have run into is prevalent. I have tried some of suggestions that were previously posted but I am still receiving the error....I will continue to try and figure this anomaly out.
Todd H
Oh and thank you to all the testers and programmers. I don't think that can ever be said enough.
Today I test for first time 3.3 rc11, two short flight to test the new controller, with standard params no tune yet and some wind; when I download the logs I find that RTL appears two or tree times but I didn't switched, I was near the copter and no failsafe err appears, I check PWM values and looks well, What can be happened?
2015-09-22 17-22-20.log
2015-09-22 17-39-30.log
Many thank's Alex, It's possible that pins are changed, I have an old 3DR Pmodule 3-4S and didn't check that, I have to invert nearly all when I change the APM 2,5 to Pixhawk (chinnese) I have the 6s PM that's arrive with the Pix, I'm going to change pins and if doesn't work I change the PM, many thank's to discover, I didn't take care of curr because I had an external alarm reading batt and looks good when I land so I'm not going to discover the issue for my oun.
Thank's for the tips, arming in Poshold it's a good idea, I almost time fly in pos hold so check looks interesting for me.
Does anyone know why Rate P and I are always the same when autotuning in 3.3? Seems a bit strange. Trying to sort out why my unit is shaking on takeoff, but flies well otherwise. Maybe not related, but still seems odd P and I are always the same.
133
134
135
136
137
of 449 Next
