Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hey Luis I guess this may be a typo? Should be Serial2 references across, correct?
Telem2:
SERIAL2_BAUD
,SERIAL1_PROTOCOL
,BRD_SER1_RTSCTS
Ref: http://planner.ardupilot.com/wiki/common-telemetry-port-setup-for-a... under rhe Mission Planner Setup section.
I do hope we can get this to work - or - you can show me what I am doing wrong . this was a key feature for my moving to the PH and AC platform-
No problem. I've already requested some corrections to the telem page https://github.com/diydrones/ardupilot-wiki-issue-tracker/issues/160
After the second mission I could not get a rearm at all even after several minutes.
MP only showed a "Disarmed" message on screen.
I will have to wait until this evening to review the logs.
I was wondering it this had happened to others as well.
I'm trying to track down some compass issues on a AUAV-X2. If I disconnect the external compass on rc12, COMPASS_EXTERNAL still always says "1" after I reboot. I tried setting manually and it always gets reset. This is supposed to be autodetected on a pixhawk - anyone else see this behaviour? The compass IDs also do no get reset - are these determined at calibration time or on boot? I had assumed boot, but maybe its only calibration?
What are COMPASS_EXTERN2 and COMPASS_EXTERN3?
Different question. If I calibrate the internal compass on its own I get offsets of (52, -104, 327), if I calibrate them together I get (-15, -32, 127). How can this be? I would expect the values to be close-ish, but they are miles apart!
Both times I had a good set of data points and the output is relatively stable if I rerun the calibration.
Or is this more a mission planner question?
Andy,
I agree with you that there shouldn't be any difference to the compass calibration results depending upon how the compasses are calibrated (how many, in what order, etc).
.. and as you guessed, it's more of a mission planner question I think. The compass calibration logic is completely within the mission planner. For Copter-3.4 the calibration will be moved to the vehicle (it's already in master).
that is apparently a support for multiple redundant compasses that would be awesome if it worked - but as all external compasses units in the gps receivers sit on same hardware address nothing of that works.
I am still on rc10 but if I disconnect gps with external compass it for sure sets compass external parameter to 0.
Never mind - I had pulled the GPS cable so the compass was connected but not powered (I'm guessing).
Disconnecting the compass does result in the external parameter being set to 0.
Popping in here to say that 3.3 rc12 ran great on my IRIS+. Granted I was not able to test every single mode and function but out of the modes I was able to fly in ,AltHold, Sport, PosHold, Circle everything went smooth. First flight no gimbal. took off fine. Got to a good altitude and let AutoTune run. AutoTune complete. Ran tests in AltHold, PosHold, Sport, Circle, Land, all good no issues IRIS+ was 100% spot on. Second flight gimbal attached. Launched fine. tested same flight modes, all good. No issues, IRIS is solid. Had 12sat 1.4hdop on both flights. Had my ground station up and running but I was flying IRIS+ a few feet away so I wasn't see what the HUD was displaying.
I would post my logs but the issue of "Error receiving log list" that other's have run into is prevalent. I have tried some of suggestions that were previously posted but I am still receiving the error....I will continue to try and figure this anomaly out.
Todd H
Oh and thank you to all the testers and programmers. I don't think that can ever be said enough.
