Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      Kurt,
      I've heard of people pulling one of the wires from the GPS to stop the auto configuration but so far I haven't heard why that's being done.  If it's because you're piping the GPS's data to another source and that other source requires NMEA then that's a reasonable idea although I worry that the 38k serial link might run out of bandwidth to support both types of messages.
      • Hi Randy - Thanks for the reply. No it's more of being able to make slight advanced changes to the GPS config in U-Center and have them not get wiped out by the forced settings in PH.
        When I installed my M8N with PH and then later looked in u-center, NMEA messaging is enabled. I have to shut that off in u-center.
        Actually you and I discussed this briefly in another thread- you suggested I use Marco's specific M8N config- which I did - but it gets wiped out each time the PH reboots so the only way to save it is to yank the rx wire.
        ref: http://diydrones.com/forum/topics/copter-3-3-beta-testing?commentId...
        sure it's easy enough to yank the rx wire but having 'gps config no override' as a parameter in APM would ultimately be a more elegant option, but I understand it's probably low hanging fruit from a dev perspective.
      • By removing the TX wire from the APM/Hawk [the RX on the GPS] the configuration is not updated on the GPS so when people make custom configurations on their GPS modules from say U-Center it is not overwritten by ArduPilot on bootup.
  • I've just had a problem with there being 4 more images than cam trigger events. (224 images, 240 trigger events) on RC11 during an auto mission. Previously I've only ever had more trigger events than images when the camera couldn't keep up, but it can easily keep up with the rate it was being triggered here.
    Does anyone know what could be going on?
    There's a log over on the thread about it.
    http://diydrones.com/forum/topics/cam-msgs-and-files-discrepancy
    • I've just found some more weird behaviour with this log while using the geo ref tool. Using a time offset then generating the location kml, the flight path gets cut off about 40% of the way into the flight, then jumps to the end position, and also has a large gap in the image locations, however using the 'create kml + gpx' option in MP, the full flight path is displayed correctly. This makes me think there's something wrong going on with the geo-ref tool, or else my log is somehow seriously broken.
      There are images showing this on my other thread. http://diydrones.com/forum/topics/cam-msgs-and-files-discrepancy
      Also my geo-ref tool doesn't give me any options to change the field numbers like it has in previous versions (and like in your screenshot Shaun).
      Edit: updated MP from 1.3.32 to 1.3.32.1 (beta updates) and now I can use the time offset without it cutting the log off half way. Still has the non-matching number of trigger events to images though.
    • Thanks for looking Randy. Sorry it was 224 images, 220 trigger events... was a typo in the last post. The card is a fast sandisk ultra 8gb which benchmarks as having a good write speed. This log is only 10mb for a 15 minute flight and I don't have any additional logging turned on, so I'm pretty sure it's not an issue with the card not being able to keep up. If there's a way to tell for sure whether this is the issue though I would like to know.
      I just want to make sure I can avoid this happening in future since I'll lose precision if I can only use the offset geo ref method (not to mention the pain of trying to get the offset right) rather than being able to use the cam trigger events.
      • Hmm yeah it is using a GentLED to trigger. Wonder if it somehow double triggered via IR, but it's all set to manual focus & no review, so it triggers pretty much instantly when it gets the signal and is good to go again quickly. I've taped the LED to the IR window and covered it over so there's no external light that can get in and mess with things. I never had any issues with image #/log mismatches on 3.2 with this same setup, so I'm wondering if it might be something else.
        • I haven't been able to geotag images for a while, on 3.2 or 3.3. I can't even find any cam_trigg messages in the log. I managed to tag in Mission Planner once recently using time difference but it came out a bit odd (registered all the photo's as a single line). Pix4D doesn't recognise the logs either. I use a relay type usb trigger on an s110.
