Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • 3702100724?profile=originalHad a strange behavior during autotune in rc12, when it was autotuning the roll axis it made a pause in the tune and yawed slowly 360 degres counterclockwise and then continued with the tune of roll axis? It finished all the 3 axis.
    The autotune was OK when it was finished, tried it for about 5 minutes.
  • when will the official 3.3 be released i been waiting a long time.. i see 12 rcs
    • Kirk: you can get a try with carefull and returned to stab release if you don't like, for my last build, I have to solve some issues yet but this release is the difference to fly and no fly so no return for me.
      Remember to save your params in case you don't like it it's easy to go back..
    • Dear James T Kirk,
      I had some OT replays in this thread which were simply ignored, and I learned the lesson.
      I am happily flying the 3.3 beta without any issues from RC9 up, with my setup, but some people did or do have problems, and I am pretty sure that if 3.3 was officially out and you had any issues with it, your anger would be all over the forums.
      I learned a lot about the 3.3 simply by following this lengthy thread
      So you can either be silent and wait for the official version like me, or you can contribute to the beta in any way.
      Or you can ask Scotty to beam you up to the new version, or just switch to DJI, Naza or anything else.
      The devs are doing a wonderful work so please let them decide when it's time.
      Just my 2c.
  • 3.3 c12 seems to have better alt hold than 3.2. Mine use to ascend going CCW and descend CW or vice versa I forget. But doesn't seem to do it at all now.
    • @Richard
      I haven't forgot the file; worked all weekend, will get them tomorrow time permitting. Sorry.
      • Thank you. I messed with it for a couple hours... still not having much luck.
    • I agree, were I have Pix with int compass, APM compass with 3.2.1 didn't works. I need more calibration but difference is noticeable.:)
