Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
+1 ; I prefer numbers too
Alright- Well it seems there is a long history of confusion on this from what I've found online. there is apparently no intelligence with the ABCD buttons in relation to the model configured. that's kind of bad. if you set up your FC for an X quad in MP, it should automatically map the motor test buttons in the correct (model setup) configuration, and use rc output pin numbers instead of ABCD etc..
I appreciate the great work on MP but it seems no one involved with the project flies quads / hexas :D on of the most important uses for motor test buttons is to ensure your FC wiring is correct to proper motor locations. As it is, that is impossible to test in MP.
WOW!!!!
Today, a windy day (as usually here) I try Richard recommendation to cover the Pix not to loose altitude, I used a salad bowl and works GREAATTTT!!!!!, It's impressive to watch this copter flying with this wind :O , impressive code too, Many thank's Richard and Dev Team :) :) :D
The only thing I don't feel comfortable with this vers is that if I change from stab to Pos hold and throttle isn't in the middle, the copter loose altitude very fast, that didn't occurs for me in older vers; It's only a detail but a newbie perhaps can crash if surprise him/her. But I don't change this vers for nothing older, It's looks much better for my complicated cuad
Richard: You can't find a solution for your Tanaris yet? .
I've learned very quickly to get the throttle stick centred before switching to Alt Hold! I think a delay on the switch and a centre stick reminder might be good. Time to tinker with my Taranis! :)
Cala - i had similar happen until I accurately set my throttle midpoint. looking in my flight data log my hover is at 33% throttle - i changed my mid throttle to reflect that. now there is only a small difference when switching between poshold / althold and regular flight modes like stab / drift. Also i changed my althold deadband to 50 from the default 100.
btw I use the rctimer.com plastic dome and flight deck combo to house my pixhawk lite FC- it is not expensive and works great.
Thank's Kurt, I'm going to play with dead band perhaps solve, I'm going to re-check the mid throtlle in case too.
This disposable salad bowl is very similar than RcTimer one, fix perfect on my cuad and is very light....now I'm dieting to have more domes ;)......perhaps looks horrible but I'm so happy than I look nice :D
very nice innovative solution. you may want to spray paint the inside of the bowl black, tape off an area inside the bowl first, in front, over the status lights so you leave a clear "window".
Good idea, Thank's
here is the rc timer anti-vibration platform and dome kit, it even comes with a nice little usb extender for easy pc hookup without removing the dome every time. http://rctimer.com/product-971.html
Hi Trent,
An overheated ESC would definitely fit the bill!!! That would explain why you didn't loose all power. Being your first flight going that long and with extra weight all makes sense.
As you said, that flight doesn't show any signs of the same problem.
Good luck and let us know if you learn more!!
