Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
what are some of you using for ANGLE_MAX? The default setting on mine is 3000 - so that would be 30 degrees, that seems a bit weak no? the wiki says that 4500 is the default, but apparently that is not correct.
something odd- i enabled motor spin on armed (MOT_SPIN_ARMED = 1), and it does not seem to be working properly. when I arm the quad the motors don't spin. I will take off, fly around, land, and the motors will stay spinning until it auto-disarms.
with mot_spin_armed set to 1, I get that the motors will stay spinning after landing until the FC disarms - but - shouldn't the motors spin up as soon as I arm the FC with stick commands? I have my THR_MIN set to 115 so it is enough to spin the motors, as evidenced by the motors remaining spinning when landed post-flight.
I have BRD_SAFETYENABLE = 0 if that helps.
I have to move throttle a little to help them begin spinning, at land stay spinning like yours, Is like they have no enougth throttle force to move.
I think that's THR_MIN ??? I turn mine up so they spin when I first arm.
nah THR_MIN only seems to govern what the props will spin at once under flight and dropping throttle. when first arming the blades don't spin - apparently it requires setting motor spin on armed value to something that represents a percentage of throttle, enough to spin the props. MP's descriptions are blank and there is no info at the wiki.
It would be really nice if any settings that govern motor spin are expressed in PWM values instead of throttle percentages. it is easy to figure out t what pwm values a motor will spin at, but using percentage of throttle is only a guess.
Yea come to think of it there is yet another setting for what the props do when armed right??... spin slowly can be selected right? But I do recall I had to bump some number up a bit to make them actually move.
Man your not lying on the throttle PWM instead of a percentage at least in 'plane' I had a heck of a time trying to figure out what to set cruise throttle with a gas engine because it would not do so on the ground for testing because it wont move the throttle until it see's it's moving for safety reason so I had to drive around with it in my truck to see how far it would open the throttle when I set it as a percentage. That was 3 years prior though so might be different now. Talk about OT!!! ha sorry.
yeh i just don't get it why a percentage method was used instead of concrete pwm values. using the radio calibration tab it is easy to see what pwm the motors spin at. Everything should always be referenced in pwm, JMHO..
I thought you have to set MOT_SPIN_ARMED = 70 for it to spin.
hrmm- it seems you are right, I thought it wa a zero = off and one = on type of setting.
it requires some sort of non-documented value which represents percentage of throttle? I found posts all over the internet ranging from 70 to 800 with no clear answer. Mission Planner description field for the setting is blank. wiki page has no info on this setting or recommended values (that I could find).
Logically thinking, I would assume that enabling motor spin on armed would use the THR_MIN value - or would that just make things too easy? ;p Why would you need to independently set the motor spin on armed speed when you have already specified THR_MIN? makes no sense.
Yup 70 is slow spin
