Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • I have two Pixhawk running arducopter with version 3.3.1 and one with
    3.4-dev. The two have a message via NSH Overtime task 19. Is there a problem in flying that way.
  • Wil there be ever oneshot support with pixhawk in the future?
    • +1 For that!
        It's tentatively on the to-do list for Copter-3.4 but I can't promise it because things sometimes get bumped.  I know Leonard Hall wants it as well so that increases the chance that it'll happen.
        • If that happens, please enable pixhawk to be an ESC configurator hub similarly to how it's done in clean/betaflight. This way people can bury the xRacer board inside the 250 frame for better ptotection.
          • This would likely be a new request, so you'll want to submit that as a request on the GitHub repo.
            • yes please, oneshot support and blheli 1wire update through copter software
              So I can use a pixhawk for 250 racers which needs fast updates to esc and processor of pixhawk is fast enough and software is excellent
              RTH functions on a racer with all the close proximity interference of all the electronics ..... :(
              Could case a lot of complaints about the excellent software which is designed for stability and not for racers, compass mot V3 for mini racers???
              I for see a lot of questions
  • Hi,
     Do the latest firmwares support V and T setup for hexacopters at all?
    3702119253?profile=original
    • I have used standard Octocopter code to fly an H-shaped Octocopter (like your hex shown, but with 8 rotors).  It worked out OK.
      Duffy,
      I'm afraid we only support X and + for the Hexacopters.  It's not super hard to add support, just need to come up with the motor mixing for roll, pitch and yaw.
DIY Robocars via Twitter
RT @a1k0n: @DanielChiaJH @diyrobocars @circuitlaunch Here's my car's view of that race. About 8.4 second lap times for laps 2 and 3... both…
Monday
RT @DanielChiaJH: Great racing against @a1k0n today at @diyrobocars! Pretty cool to both break sun-9s at the track today I think I got very…
Sunday
Broadcasting the @circuitlaunch race live now at https://m.twitch.tv/diyrobocars Races begin around 2:00pm PT
Saturday
RT @a1k0n: ran a huge number of hyperparameter tuning experiments yesterday; now I can train a new policy, far with better quality, in 15 m…
Saturday
RT @a1k0n: Did I get rid of hand-tuned parameters? Yes. Am I still hand-tuning more parameters? Also yes. I have a few knobs to address the…
Sep 26
RT @a1k0n: I'm not going to spoil it, but (after charging the battery) this works way better than it has any right to. The car is now faste…
Sep 26
Sep 26
Sep 24
Sep 24
Sep 24
Sep 23
Sep 22
Sep 11
Sep 10
Sep 10
Sep 10
