Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          • I'm the same way I can't STAND the idea of taking off in any other mode except stab. Then I get it to where I want it. Then switch to alt-hold, or loiter, or auto etc. Took me FOREVER to allow it to auto land land and I STILL rarely do so unless I init RTL or end a mission.
            • if you engage RTL in the end then it is absolutely required to change routine and engage GeoFence so firmware will not let you to start and fly until system acquires acceptable GPS lock and gets your initial position correctly, otherwise your start with GPS coordinates from who knows where may result in RTL into who knows where.
              GeoFence is annoying as it takes forever for it to finally acquire that '3d Lock', whatever it is, as it may sit 5 min or so having 13-14 sats in 3D mode before it finally satisfies, but afterward it is flying OK.
              Also, after my fights with drone doing toilet bowl and other GPS glitches - an only solution is to buy a separate BEC with a _very_ good LC filter and power your GPS units from that separate BEC, not from your flight controller COM ports. Difference is quite dramatic, in both speed to acquire locks and with in-flight stability.
              After all that done I am now always start in position hold and vehicle does not dart sideways anymore, does not try to fly away anymore either. Only other thing - on dual GPS vehicles you still need to change the option to disable automatic GPS receiver swap function until Randy and Co will change logic not to use actual physical coordinates from GPS units but an average delta between positions GPS units return, as different GPS units never return same actual number for coordinates no matter what you do.
              Code really needs  to be adjusted to take care of that - to trace actual movement delta from both units and not actual coordinates value as latter results in the drone darting from one stable position to an another.
              • Hi
                I us a Ublox NEO-M8N as my main gps which gets 15 sats in my living room and a second 3dr gps which is still thinking about getting a lock in the house with gps auto switch on it never actually switches gps but 3dr one is there should the m8one gps one fail as I go a couple of miles out best be safe than no backup
                Stuart
  • Loaded 3.3.2 rc2 on my 450 and 550 quads. Autotuned both and flew a bit this afternoon.  All went well.  Only thing I saw was the 550 tended to have a minor  "quiver" side to side.  Probably a slight vibration problem.  Was testing new props.  Will fine tune and recheck but believe that it is my problem not 3.3.2 rc2.
    Thanks Randy & team for your excellent work and fast turn-around.
    Michael
  • today more flights, more test switching to stab and pos hold and works well
  • Anyone run autotune with parachutes on board and armed?  Just going to autotune a new rig that happens to have dual Skycat's on board and wondered if it would be a good idea to take them off.  Wouldn't be all that great if they fired lol!  The chutes are designed to save the payload...  But not the multi rotor so much at about 17'/sec.
    • Yes, I run autotune with parachutes on board and armed, no problem
  • Is there no THR_MAX parameter in 3.3.x? I have gone through the wizard for a Hexacopter in X, but my parameters do not include a THR_MAX and my copter will not take off (motors spin and almost take off, but do not).
    Attached pic showing no THR_MAX after using the wizard for Hexacopter in X.
    https://storage.ning.com/topology/rest/1.0/file/get/3702130280?profile=original
    • Anyone else any thoughts? I have done tons of searching, but no luck getting any closer to finding this setting.
    • It will be nice once the Wiki catches up on all these changes. Just a shot in the dark here but what is your MOT_THST_MAX set at? Mine is 0.95.
