Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Brad,
Sorry for the slow response. I may have answered your question on the APM:Forum but in case that wasn't you, you can use MOT_THST_MAX to reduce the maximum possible output to the motors.
Stuart
pretty sure he said he is running DJI opto and DJI motors which means he can't run the endpoint calibrations as the DJI stock firmware doesn't support it.
I'm having lots of problems with mavlink telemetry both through bluetooth and minim OSD. minim OSD now almost never works. Resetting the board doesn't help. Repowering very ocasionally works. I think its more likely that these devices simply aren't receiving mav data. Is there anyway to make this more reliable? I'm also going to try going back a couple of revs because it wasn't this bad before. Could still be my hardware, but just seems odd.
Its as simple as setting correct SR settings for the correct SR port# and choosing the correct serial port. P.s. also, if you are using a **hawk its a god idea to reflash bootloader.
p.p.s. Do not forget to disable flow control for the minimosd serial port.
You actually might be right - a bunch of these settings appear to have been changed. I didn't do it so I guess it happened when the firmware got updated. Grrr.
Yeah, I've done all that and its been working fine until the last couple of days
@Nathaniel Tyson Taking off in GPS modes or Alt Hold has been SOP for quite some time with other flight controllers. It doesn't strike me as the best of ideas but nonetheless for many people it's totally normal and if you have a good GPS signal there's really no reason not to.
Oh I see, Seams like an odd thing to do to me, lose sensitivity at a critical phase of flight. But to each there own. Thanks for the response.
You don't actually loose responsiveness, it's just a different approach or style to lift off. You raise the throttle up to around 50% and the flight controller ramps up the speed as required to get it to hover height. I think it came from the evil world of DJI.
