Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    Hi Cala and Goran
    Thanks for that. So is rc2 considered safe and stable to use? Is there an expected release date?
      I was planning in pushing AC-3.3.2 as the default over the weekend but got caught up with the xracer so I'm just reviewing the support forum and this thread to ensure -rc2 hasn't caused anyone troubles.
      It's not too different from AC3.2.1 so I think it's generally safe to fly.
      • T3
        Randy,
        have you made any tests so far regarding the ICM-20608/MPU9250 and 4kHz sampling to eliminate the need for vibration isolation? ;-)
        Looking forward to AC 3.4 (3.5)!
          I haven't done any tests with the accels running at 4kHz but it keeps coming up in the discussion with Tridge and Paul Riseborough so I think it'll happen at some point in the next couple of months.  Both the XRacer and the NAVIO+ have this IMU and hopefully most manufacturers will move to this IMU sooner or later.
        • Are you referring to Linux rt AP like a Pi2 Navio+?  This would be nice to see.  Just got one : )
          • T3
            Shaun,
            I was referring to Randy's comment about the XRacer. It is the first autopilot of the new FMUv4 Pixhawk generation (see: https://pixhawk.org/modules/pixracer and http://www.auav.co/product-p/xr-v1.htm) and it is already (partly?) supported in the master branch. So it will be interesting interesting to follow the development.
            And since the Navio+ also has an 9250 on board...
    • You are an experienced pilot, nothing is safe and stable guarantee with this toys ;) It's as your oun risck, but if you use the stab release, be carefull to switch from stab to loiter, pos hold, etc., I try many times with beta and the issue go away, but I'm only an user, Randy go to send to stable when he consider safe but really I like this last vers, great dev work. What vers is your last one?
        Hi Cala
        Yes, I fly OK but I loaded ver3.2.1 after some repairs a few weeks ago and then put it away to work on a project then came back to this and just wanted to catch up.
        The snow will stop me flying until the weekend so I can wait until 3.3.2 becomes the default, Thanks Randy , great work.  your ongoing development is superb.
    I been away for a while, which is the " good" version of the software? This is for a 450 size quad.
    • Copter-3.3.2-rc2 is available through the mission planner's beta firmwares link. Changes are in the release notes
      (https://github.com/diydrones/ardupilot/blob/master/ArduCopter/Relea...) but here they are along with a video
      showing the major reason this version is out.
      1) Bug fix for desired climb rate initialisation that could lead to drop when entering AltHold, Loiter, PosHold
      2) Fix to hard landings when WPNAV_SPEED_DN set high in RTL, Auto (resolved by using non-feedforward alt hold)
      3) Reduce Bad AHRS by filtering innovations
      4) Allow arming without GPS if using Optical Flow
      5) Smoother throttle output in Guided mode's velocity control (z-axis now 400hz)
