Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Thanks for the product. RB
No problems here. Stabilize, alt hold, pos hold, auto mission, land all worked fine no issues.
+1, No more change mode issue
1) when i raise the trottle stick, nothing happen till 90%. In the logs there is 90% thrIn and about 45% thrOut. Same with pitch and roll for example, the copter starts to do the action when the stick is shortly before its limits.
2) since rc2, mission planner / tower says "check throttle threshold" and it is not possible to arm until i uncheck the receiver failsafe. It worked till rc1/rc2 I think
Nothing changed in config, did the normal wizard to configure all.
Would be very nice if you can help, randy! ;-)
Re-calibrate your ESCS and make sure your throttle hover is set back to 50% until you get it worked out.
+1 from me - I have done many flights on my QAV250 with rc2 good success. My only snafu was my serial settings getting borked, but I suspect that's a MP issue.
BTW did you see my question about "Accelerometers not healthy"? I was flying one day with rc2 when it was much colder (0C rather than 15C) and I was getting these all the time. Does switching off IMU2 disable it for pre-arm checks also?
Plugged mine in in the house about 20 deg went outside armed and flew then after a few mins would not hold position as it was 0degs
started to slop off so I think gyros or accelerometers didn't like temp change
Reconnected power outside and flew fine once it calibrated it's self at colder temp
Stuart
you should ALWAYS ALWAYS ALWAYS let it acclimate before taking off. You are begging for disaster otherwise. The sensors NEED to acclimate. If it is warm inside and cold outside I always let it sit unplugged for a good 20 minutes before even thinking about plugging in the battery. These MEMS units are super sensitive and heat/cold can affect them in all kinds of scary ways.
Is it possible to incorporate temperature calibration similar to the one that implemented in OpenPilot Revo? It seems that OpenPilot is essentially dead now, but they had lots of good ideas, which may improve APM, thermal calibration is one of them.
If using a hmc5883L it would [and most things are still using this] but if you are using a hmc5983 then I don't think it needed as it already incorporates temp compensation.
