Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
That is just a warning about upgrading to that version and the need to re do the calibration. See Note 2 in red in top post from Randy.
aah, so thats means nothing to worry at all about that.. just redo calibration. thanks ^_^
Hello, with the CES 2016 Announcement of Multi point cable Cam and Follow Me Free Look, is that something that would be available earlier in Pixhawk as a flight mode as opposed to the SOLO App? thanks in advance
https://3drobotics.com/ces-3dr-drone-2016/
Yes, that's true but Solo's "cable cam" also controls the gimbal though and allows the user to pull back on the sticks to control the vehicle's position along the virtual cable I think.
I don't mean to say it's anywhere near as refined as what in the solo it's just something similar.
thanks for the Response Bill but i think Randy answered this question succinctly enough! the feature really does alot more than just adding waypoints, which i was aware of.
Thor,
No, I'm afraid those features are in the Solo's companion computer and are closed source. It would be nice if it was all open souce and that could be done if a community developer went and re-implement many of those features in an open source way within ardupilot but for the moment, I think the dev team has it's hands full with lots of other things. I think it's also fair that manufacturers using ardupilot (including 3DR) be able to differentiate themselves with features that specifically suit their market niche.
thanks Randy i was hoping you and your team were involved in it in some way and i could get a sneak peak earlier...ok i lied i wanna use those features NOW! :P thanks for the response Randy
Any chance we can implement additional battery monitor simultanesly ?
https://github.com/diydrones/ardupilot-wiki-issue-tracker/issues/154 http://diydrones.com/group/apmusergroup/forum/topics/how-to-monitor...
42
43
44
45
46
of 449 Next
