Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Hi everyone,
    I was enjoying 3.3.2 but suddenly had crash  :( . I think one of the motors/prop/esc just stopped at ~55m and then just saw it falling
    Could you please help me figure out what happened ?
    Log here: https://www.dropbox.com/sh/033wkud5adiw7b9/AABEjRVYZaQEs6d8-mLwrSyN...
    2015-12-25 16-56-49.bin
    Dropbox - Error
    Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
    • Anyone kind to take a look please ?
      I cant really figure out what happened. It was fine before 3.3.2...
      • it looks a mechanical failure in motor 3, check it
        3702732112?profile=original3702732184?profile=original
        • Thanks for taking a look Cala.
          It also could be #4 right ? and 3 tries to compensate ?
          It is for sure the motor or could be the ESC ?
          coincidence or not the ESC #3 got pretty damaged upon hitting a wall (some capacitors and a few other components were gone), it could also be the case that it was this one that caused the fall and coincidentally the one that hit the wall, right ?
          I've bench test all the motors / and the three esc's remaining and everything works. 55m fall and not even a single propeller broken (damn APC propellers are made of steel ahah)
          • For me motor 3 is the problem, I'm not an expert but if I'm incorrect anyone else shure correct me watching the graphs. esc can be the problem too but a pitty that you can't test it. If you can't find nothing, repair it, test near the floor and then read log if you notice any ERR message, check connections and wires too, looking for any little damage.
  • hey there, I have a 250 sized quad running AC 3.3.2 on a PX4mini board by airbot, there were couple of compass related issues which I think I've sorted out, however when I attempt to take off copter starts spinning around itself very fast (keeping horizon though, kudos devs!) I've tried to determine what's the issue is but as far as I see from the logs there are no errors and RCin4 corresponds to actual stick movements. Can someone take a look at the log below to help identify the issue?
    p.s. log is from AC3.3.4dev but the quad behaves the same way on AC 3.3.2
    2015-12-28 22-47-36.bin
    https://storage.ning.com/topology/rest/1.0/file/get/3702153064?profile=original
  • Finally the rain and wind stopped! Did some flying with 3.3.2 and saw some weird behaviour. I occasionally get these huge spikes in ErrRP, ErrYaw and EKF SV & SP. Haven't seen these before that I recall. A couple of flights show these the rest do not. The flying conditions were calm and the copter behaved well in flight, but these spikes seem bad. I can't find any correlation with GPS glitches, high vibes, mag interference or any of the usual suspects.
    [Note to Leonard, I also tried some 5045BN's for the first time and needed even greater divergence between P&I on both Roll and Pitch for stable flight. I've pretty much given up on autotune for this copter at this point. The attached log is for 5030's however.]
    124.BIN
  • I think this is the correct one.
    Sorry if in the previous post I had attached the wrong one.
    2015-12-29 10-17-22.bin
    • Hello Andrea,
      I had a quick look at your log and it seems that you have a problem with your center of gravity, you have your rear motor pushing harder thant the front one. Check if your copter is balance, and then verify that all your props are in the same alignment.3702609766?profile=original
      I made tests with bad motor mounts alignement and I had a CW/CCW bias that ended by yaw drift with throttle change and a small loss of stability during heavy yaw command. Here are my motors outputs before/after proper alignment to get all props in the exact same plan:
      3702609805?profile=originalOf course, after alignment I had no more yaw strange behaviour. I hope this may help you to fix your copter.
DIY Robocars via Twitter
Videos from the ICRA autonomous racing workshop are now available: https://linklab-uva.github.io/icra-autonomous-racing/
Thursday
RT @SmallpixelCar: Prepared race track for Warm Spring Raceways @wsraceways and looking forward to test my new car at RAMS RC @ramsaicar fa…
Jun 6
RT @f1tenth: Trying out some nasty blocking maneuvers 🏎️🤖 #f1tenth #autonomousracing https://t.co/nMTstsaogM
Jun 5
May 27
RT @araffin2: I will talk this Saturday from 18:00 to 19:00 Paris time for the @diyrobocars community about learning to race in hours using…
May 27
RT @a1k0n: Luckily the infeasible hairpin problem was easily reproducible in simulation and I could test the fix before bringing the car ba…
May 26
RT @a1k0n: Another problem was that I was over-constraining the car's allowed accelerations, so it didn't think it could turn as tight as i…
May 26
RT @a1k0n: Breaking the map up into two halves worked, but I had to be more careful about separating the inner track from outer. There's se…
May 26
RT @a1k0n: Here's a datalog for my fastest lap of the day. Lap timer is tiny window lower-left. https://t.co/myrlWWrKUY
May 26
May 26
RT @a1k0n: Here was my car's POV. Man this track is confusing in first-person! After the incident my camera was all scuffed up and I was af…
May 23
RT @circuitlaunch: Loved seeing so many familiar (masked) faces at Circuit Launch today for our first in person @diyrobocars in over a year…
May 22
RT @circuitlaunch: Last but not least, mystery guest @BostonDynamics Spot took to the track @diyrobocars He enjoyed the #brazilianbbq too 😂…
May 22
RT @SmallpixelCar: Today’s race @circuitlaunch for @diyrobocars with @a1k0n Was busy in the morning and did not get a chance to tune camera…
May 22
RT @a1k0n: This was epic. My car was barely working this morning, had to make a lot of changes and extremely dirty hacks. Post-race analysi…
May 22
DIY Robocars @ Circuit Launch, 3/7/2020 https://twitch.tv/diyrobocars
May 22
