Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          • I understand that before AT process you can compare old and new pids turning on/off ch7/8 during the fligth and how pids are when you disarm are the saved pids (new with switch on or old with switch off) ; but before autotune I don't have enougth batt to many test so what I do is: first to save the old pids-autotune-change batt-test if I like it or reload the old ones (.....But my english is not warrantee so correct me if I'm in a mistake)
            • What I did the last time was use a dial on my TX for ch 7 then set the P the I and the D one by one by dialing in each one up until it's was too twitchy then just back it off a bit. Very cool.
          • I've never done it that way After AT finishes I switch to stab then land and then disarm. Pids are always saved for me. Though I still prefer to use Sw7 to turn on/off AT and whether or not I actually use the PIDS set by AT is a different discussion all together :)
          • it sounds wrong,you just land and disarm ,and pids are saved..
  • This reply was deleted.
    • Did you put the CH6 Opt on the Config/Tuning Page to "None" ?
      I use Ch 7 and it doesn´t work unless i put CH7 Opt to "Do nothing".
  • Reuben, I migrated to M8N too from Lea6, I only put a cooper sheet little bigger than the unit, solder a ground wire to the cooper and plug in grn Pixhawk, I changed from 10 sats with Lea to 14 and them to 18-20 with the cooper but no extra config; did you check the wires? one time I had problems with a new one, good luck.
    • Hi Cala
      I did make a small shield it was better but the main issue is high  velocity bar and positions Horiz errors on the EKF viewer.. the 7M seems better. when i get the Horiz error copter shoots off to some else ..  i have to be quick ...although once i let it continue and it did come back and continue the mission. Funny thing is the other machine is using a M8N no fancy mods at all  and has done over a hundred missions no issue ..granted it is not running 3.3.2.
  • There seems to be a few of issues.
    1 being you are not waiting long enough after powering up to let all the sensors and GPS settle down before flying.
    2nd being you are flying too low and running a mission.
    3rd your craft seems highly under powered and is struggling to maintain altitude.
    • My trouble seems to be around this Horiz Variance message . . what is it where does it come from, gps or compass .. or accel's.?.I note i do see a volcity bar goo a bit too high once or twice in the replay too ?
