Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • You have a flight mode err, you solve it?
  • Hi Group,
    I am experiencing high Y values compare to X when plotting with FW333 Vibe feature.
      I am trying to gain understanding why and which possible solutions.
    Without repeating myself,  I have made the original post with all the details and files  here -
    http://diydrones.com/forum/topics/vibe-xok-ybad-imu-problem
    http://diydrones.com/forum/topics/vibe-xok-ybad-imu-problemhttp://
    Is there someone here with whom to open a discussion re my percieved problem?
     or can you please point me in the right direction as to why the Y-param is so much than X
    and what I can do to investigate the source of this perceived problem further or solve it?
    Thanks for your valued input.
    Gerhard
    Cape Town, South Africa
    3691297686?profile=original
      Gerhard,
      The Y values are certainly much higher.  maybe something is bouncing into the board.  In any case, they're not so bad that it won't fly though I think.  Below 20m/s/s is within the acceptable range so unless you're seeing problems in flight, I wouldn't worry too much.
      • Hi Randy,
        Following-up on my results and possible solution, as per recommendation from Vesselin,
         herewith the current thread link -  http://diydrones.com/forum/topics/ac3-3-vibration-logging-discussio...
        btw - Can you advise progress and possible release-date for Copter 3.4 ?
        Gerhard
      • Hi All,
        Thanks for your feedback.
        The craft 'appears' to fly ok in stbls, altH,PosH even though the Y-axis is 'off'.
          btw, just to be sure, the Y-axis indicates vibrations in the side-to-side movement
        and NOT Front/Nose-to-Back movement?  Please correct me if I am wrong here?
         I am going to continue this discussion in the link hereunder, so if you any furhter contributions,
         I will appreciate it if you can follow the link -
        In this Link I have loaded Build-pics
        Thanks everyone, I am looking forward to your valued and experienced input
        in order for me to learn and grow my knowledge to enjoy this most interesting technology.
        Gerhard
      • Randy is right as usual, but he is a brave man ;-)
        I am not and would like a calm controller...
    • I sent you reply in the other thread: too much Y vibrations.
  • Here is my S900 with AP3.3 on Pixraptor in "War of drones ;-)"
    3702242340?profile=originalPhoto by Ventzi Petrov in Rhodopi mountain (Bulgaria).
