Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Yes, I think you could be OK. I have done this before, dropped a quad right in a lake. Grabbed it out, dried it out, and it all worked, even the fpv camera and transmitter amazingly. I thought for sure the camera would be toast.
The key is to get the power off ASAP, and then get it all dried out ASAP.
Indeed taking the power off was the first thing to do, as one of the motors was starting to smoke-up, I guess the controlling ESC had shorted out...
These are replacements for sure...
place your electronics in a bowl of rice and leave it for a day..
Was doing a test flight the other day and when the battery failsafe kicked in it flew to the location where an EKF error had cleared and just hug there. I was able to reposition the copter to a closer spot but it just hung there in RTL.
Finally the battery went dead and it was no longer able to keep it in the air.
At the point where the EKF error cleared is close to where the HDOP went below 2.
5125.bin
Michael,
Thanks for the report. I think the vehicle was armed and was flying for about 1minute before the home position was captured. I suspet this was the problem. Apologies for showing your flying location (it looks nice!) but it helps clear up what happened... the upper red pin shows where it captured home and it should have tried to RTL to that location. In fact, it came down where the lower red pin is (end yellow line). Maybe it tried to come down at the "home" and you manually repositioned it to the lower red pin?
We've certainly made changes in this area of the code as we added support for the do-set-home command so it could be a real problem, if you can remember where it came down that will certainly help.
When running 3.3rc1, I too have noticed that home is where it captures 3d lock and not where it is armed in both takeoff and RTL. When taking off, as it is ascending it is moving over this initial home where 3dr lock occurred. To be safe, I have been applying power and getting 3d lock where I want it to takeoff and land..
That is where it set down and bounced until it landed.
I thought I checked where it set home at. Makes sense that's where it flew too. It must have know there was a tree under it so it didn't land.
Now the problem is knowing where home is. If it just picks a random spot that it got a good GPS signal, home could be anywhere. Also effects where my fenced in area is as well.
Like the new tones though. More positive feed back as to what's happening. Don't like the new failsafe alert though. Wakes up the neighborhood.
Hi
Yesterday I installed AC 3.3 rc1 and today I ran Autotune. The result is not good, there is some overshoot, the yaw jumps.. Adds a log of my flight
best regards
2015-04-15 08-18-41.rar
Hi Lukasz,
I can't seem to download your logs but we have a consistent issue with the change in the way we filter the gyro's has caused an issue with auto tune that will be fixed in the next release.
Ok thanks for the information. Log rar packed because he had more than 17 mega and joined to the previous post ...
