Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Michael,
Thanks for the report. I think the vehicle was armed and was flying for about 1minute before the home position was captured. I suspet this was the problem. Apologies for showing your flying location (it looks nice!) but it helps clear up what happened... the upper red pin shows where it captured home and it should have tried to RTL to that location. In fact, it came down where the lower red pin is (end yellow line). Maybe it tried to come down at the "home" and you manually repositioned it to the lower red pin?
That is where it set down and bounced until it landed.
I thought I checked where it set home at. Makes sense that's where it flew too. It must have know there was a tree under it so it didn't land.
Now the problem is knowing where home is. If it just picks a random spot that it got a good GPS signal, home could be anywhere. Also effects where my fenced in area is as well.
Like the new tones though. More positive feed back as to what's happening. Don't like the new failsafe alert though. Wakes up the neighborhood.
Hi
Yesterday I installed AC 3.3 rc1 and today I ran Autotune. The result is not good, there is some overshoot, the yaw jumps.. Adds a log of my flight
best regards
2015-04-15 08-18-41.rar
Hi Lukasz,
I can't seem to download your logs but we have a consistent issue with the change in the way we filter the gyro's has caused an issue with auto tune that will be fixed in the next release.
Ok thanks for the information. Log rar packed because he had more than 17 mega and joined to the previous post ...
Try to reduce "Stab and Rate" YAW P about 1/3.
I use this trick also for Roll and Pitch, a little overtuned on my big birds, like in my video on this thread.
HI!. Thanks for the information always so I do from AC 3.1.5 and it works quite well. But now, Pitch and Roll has a very low P rate and very high I, while Yaw too high P and I corrected what I can in this way
Yeah, Leonard had already warned of this thing in my test phases.
Hi! How many minutes does autotune require to complete the entire cycle? I am having a hard time doing so since my flight time is just 7-8 minutes with my current setup.. I always end up landing the quad due to low voltage...
438
439
440
441
442
of 449 Next
