Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          Hi Arni,
          Yeh, there are a number of changes that mean some people may need to retune.
      • Hi Leonard
        EKF_GPS_TYPE in the MP full parameter list page is set to 0. But the log shows 1. I guess this must be a bug. Before I installed RC4, I installed the ArduPlane firmware in attempt to get rid of any old parameters.
      • Thanks guys,
        I will test again with new settings and report back.
      Hi Arni,
      There seems to be a lot more noise on IMU 2 compared to IMU 1 in the z axis. Funny thing is it is the opposite way around with gyro noise..... Strange.
      There also doesn't appear to be any innovations of the vertical gps velocity and the position estimate in the vertical seems a little large.
      I am sorry but I can't see any obvious problems. I will have to wait and see if Paul sees something.
  • Is the DCM Bad Heading warning I keep getting in 3.2 fixed in 3.3 or better? Was / is this a code related issue? I've searched the forum and it seems it wasn't all just set up or calibration issues.
    • I don't think this is software. Probably either compass or vibrations. I would heartily recommend you try 3.3 because you can get a log of compass health and eliminate that. Do you have an external compass? Do you have a log with this problem in?
      • I'll try 3.3 next weekend when I get a chance. It's not at my current location. I'll save a log from 3.2 first though. Vibrations are very very low. Alt hold is excellent. I do have an external compass on a mast. This entire set up flew without this issue before but after I re-flashed 3.2 it started giving me the DCM bad heading. Perhaps I should re-callibrate the compasses? Do compass mot again? My offsets are low all except one on the internal is 525. But the external is real good nothing over 80. It's not reliable now,,,,  several times I've had to flip modes to stop it from landing. Not good. Thanks Andy
        • I would redo the calibration. If 3.3 shows the health is bad it may be something simple like a loose connection. Your issue sounds very like mine where the external would go unhealthy and then the FC would flip over to the internal which was less accurate. 3.3 won’t do this, but of course if your compass isn’t working properly then you will soon know about it!
  • Something else I noticed going from 3.2 to 3.3 are the imax setting on roll and pitch.  They used to be 100 and now they're 200.  I asking because I've got this unit flying great in 3.3, but will wait for 3.3rc5 with with the gyro issue.  Commercial users shouldn't be messing with beta lol!  So if I go back to 3.2 and use the pid's I've got in 3.3, do I leave the imax at the 3.2's default of 100 or set it to 200?
    • Are you seeing those Imax values in the tuning page, or the full parameters list? (there's a rescaling that goes on for some reason that makes this topic always confusing).
      Based on the Full Parameter List, which are the actual values, I'd say that 100 is way, way too low.  You should have 1000 at the least, 2000 is better, and I typically use up to 4500.
