Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
thanks for the feedback. I stll haven't flow yet because I am still getting more feedback about these errors. Hopefully such errors wont affect the flights, it would be troublesome if it would cause a fatal crash..
i got that error before I update to the latest beta firmware of Mission Planner. But now the error prompt just changed to EKF PRED POS HORIZ ABS. THe quad arms with no probs. But I am a bit concern with these EKF errors..
the version of my Mission Planner is 1.3.27 build 1.1.5620.38044
I got the same phenomena, F/W 3.3 MP 1.3.27....any solution for this problem?? thanks
Randy, im still getting the error EKF PRED POS HORIZ ABS
my question is, should I be concerned with this error? Will it affect how my pixhawk fly? Thanks again!
Started testing break mode with rc4 then today with rc5 - it appears if you arm the copter in loiter mode, leave it with minimum throttle and attempt to switch to break mode it does not stop the motors and does not trigger disarm - I believe pixhawk does not even switch to the mode (still accept throttle input). However with throttle above minimum (still on ground with very low throttle) it works.
AC3.3-rc5 is available through the Mission Planner’s beta firmware’s link. The small number of changes are in the ReleaseNotes and also below.
Changes from 3.3-rc4
1) Fix AHRS bad gyro health message caused by timing jitter and log IMU health
2) TradHeli gets better default rate PIDs
3) Small changes/fixes:
a) GCS can use MAV_CMD_MISSION_START to start mission in AUTO even without pilot raising throttle
b) GCS can force disarming even in flight by setting param2 to "21196"
c) rc-override timeout reduced from 2 seconds to 1 (applies when using GCS joysticks to control vehicle)
d) do-set-speed fix so it takes effect immediately during missions
e) GCS failsafe disarms vehicle if already landed (previously it could RTL)
We still have two or three fixes to go into AC3.3 but I think we’re getting close (please tell me if you don't think so!). Thanks again for your testing!
Randy,
is there any chance that Paul's PR to use GPS height for navigation (https://github.com/diydrones/ardupilot/pull/2310) will make it into 3.3? It can be switched off, so the general behavior will not change.
Best regards,
Thorsten
Thorsten,
It's missed the cut-off it seems. We just need to draw the line somewhere and that patch hasn't made it into master yet. Sorry!
Hi Randy,
I just started a series of tests.
A baro altitude drift of about 5m seems to be normal for flights > 20m.
I posted posted some logs for Leonard showing some Brownout Fails:
http://diydrones.com/xn/detail/705844:Comment:2020454
If you are planning to rebase rc6 on master to integrate the vibration logging (which would be awesome!) I would really appreciate if you could reconsider integrating Paul’s small GPS height navigation PR.
Randy,
thanks, I'll test it with 3.3 and looking forward to see it implemented in 3.4 officially.
A little OT: I wanted to submit some PRs but "git config --global core.autocrlf false" is not working for me on windows. Any suggestion?
375
376
377
378
379
of 449 Next
