Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I think Randy mentioned that if you had a 3 position switch, middlepoint was some sort
of auto, but what it do i have no clue. Havent tried yet
Hi
ublox GPS is not detected when i tried 3.3 rc5 on px4fmu+px4io. Works ok on ac3.2.1 though.
used 3dr GPS + compass and quanum GPS + compass both not detected on 3.3 rc5 but detected on version 3.2.1
Yesterday I flashed the V3.3-rc5 to my PixHawk hexacopter, but now I can't get to download the log anymore.
In the MissionPlanners (latest version 1.3.28) CLI it only gives "mumbo jumbo".
In the beginning it says:
Waiting for reboot
Opened com port
3Initialising APM...5? (NO mention of Arducopter 3.3-rc5)
Then the mumbo jumbo starts.....
What am i doing wrong?
btw Arducopter V3.2.1 gave no problems.
Paul,
Download the Log via Mission Planner Terminal does not work anymoe from 3.2 and upwards.
In Mission Planner go to FLIGHT DATA and sellect "DataFlash Logs" under the HUD screen.
Than click "Download DataFlash Log Via Mavlink".
Hope this helps.
Geert is correct but I didn't understand how Paul said " Arducopter V3.2.1 gave no problems"!..
The last release version that used the terminal to download the logs were 3.1.5. Terminal removed after that.
AC 3.2.1 should be same as AC 3.3 rc5 as far as the log download is concern.
anyone tried out storm32 and tower at same time ?
my tower goes crazy ...
https://youtu.be/KzHd5ndXE84
It's probably because tower is picking up all the mavlink messages from the storm32 and not filtering them out. If tower has an option for specifying a particular system id and component id then try setting them to 1 and 1, if not then it probably needs a bug/issue filed against it.
I had the same problem with teensy telemetry and had to recode it to only listen to mavlink messages from a specific system/component id.
In the full parameters list the options for setting serial 4 protocol and baud are missing even though the second GPS parameters are included. When will the serial 4/5 parameters be added back to enable secondary GPS module use? Or is there another way to enable this that I am unaware of?
A second GPS is critical for UAV Outback Challenge operations, especially on small copter frames where RF separation is difficult.
Regards
JB
Autotune 3.3 rc5: frame x8 motor U5 propellers 16"+17" weight 9 kg (4 autotune, 4 different results)
Hi Antonio, what were the other results?
