Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          • No idea. Your log looks perfectly fine apart from this error. My only guess is that you are moving the copter while the gyros are calibrating. Make sure you keep it absolutely still when you plug the battery in.
      • re- I tried disabling each of the compasses but I think that the EKF check ignores this and continues to check both.
        Yes I remember Randy was going to look into making sure it actually ignored the compass during the initial checks if that was selected.
  • DIY tricopter question: I loaded 3.3-rc5 today (coming from 3.2.1)-- have there been changes to the Yaw mechanics? My yaw is now very sluggish/spongy in responsiveness. And it does not stop quickly when the stick is released, it slowly yaws to a stop (alt  hold/stab/pos hold). Sometimes making a complete 360 if I'm making an aggressive turn and let go of the yaw stick. Reset everything to defaults/recalibrated/etc... same result. It used to be very aggressive in trying to hold/stop at the position when the yaw stick was released.
      Hi Michael,
      This is probably the Rate Yaw Filt number. If you increase it to 40 this should fix your problem.
      I am trying to get a tri built now so I can support the tri pilots better.
      • Hello Leonard!
        My octocopter with 18" props with original PixHawk on 3.3 rc5 also sluggish turn. And on 3.2.1 also sluggish turn. If wind >3-4m/s yaw copter sometimes turn 360 angle without my control.
        Please, help - how to adjust to Yaw he did not turn in the wind? Yaw PID is factory default. pitch and roll i ajust.
        And in my config on 3.3 rc5 param RATE_YAW_FILT_HZ=5. Increase this parameter for precision yaw?
          Hi Aleksey,
          No, leave that at 5Hz and experiment with increasing Rate Yaw P. Auto tuning Yaw should also help but I am making some changes that should improve things a little for yaw. These changes should be out in the next release candidate.
          • I had to increase YAW_P and _D drastically on my monocopter too. A question: does increasing these parameters beyond the range specified in Full Parameters List have an effect?
              Hi Peter,
              For most of them yes.
              • Thanks Leonard!
                We "monocopter" enthusiasts are quite in the minority, had to ask here amongst the multidudes...
                Actually, it's an asymmetric bicopter...;>)
      • Thanks! Will do. It is set at 10 now (default). I'll give 40 a try and report back. I'm not sure what use a log file would be but I've attached it-- just my last run tonight (just tinkering in the yard in the dark),  You can see here where I was stationary in alt hold  applying 100% yaw (it does several 360's), I let go of the stick and it looks like it did another 360 before resting. (well, okay... log is to large to attach, will see if I can link it from work tomorrow)
