Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • My fpv is on 5.8 but I've eliminated that so far. However my RC is on 2.4 so that could be an issue. I've violated one of the rules of troubleshooting by changing two things at once (moving FrSky antenna and unplugging the 915Mhz telemetry radio) but I've been able to arm now. It remains to be seen how repeatable that will be.
        In any event you guys led me in the gps interference direction and that might well be the problem. If this is repeatable then I'll re-connect the 915 telemetry & see what happens. Would be nice to know if v3.3 does more checking of gps position information quality than v3.2 was doing which would explain why this is just happening now.
        • It appears that v3.3 with its EKF algorithm implementation is handling gps "glitches" differently, and probably much more rigourously (spelling???).
          In any event I have found that the gps interference was most likely caused by the 915Mhz telemetry radio. I put the RC antenna back to original position & it didn't appear to make a noticeable difference. I'll move the telemetry radio to the opposite side to see if it was a proximity problem (gps is on a pedestal on top, telemetry radio in mid section with antenna hanging down) or if it's conducted interference though the wiring.
          Although this problem caused a minor inconvenience, I'm pleased to see that the latest firmware is more thorough in checking the integrity of all systems before launch.
          Thanks Craig, Paul, & Wes for your help, and a big Thank You to the Dev Team for all the hard work! I'm liking V3.3.
          • That's odd for sure since my 915Mhz telemetry radios are about the only thing that do NOT produce any noticeable noise lol.
            • I've seen an instance of the 3DR 900Mhz mavlink radio making a Pixhawk throw up lots of IMU errors, but the antenna was both horizontal same as the Pixhawk orientation, and fitted barely 20mm from the side of the case. That was nearly as bad for RF coupling as you could get and easily fixed by more suitable antenna placement.
              Also had my FrSky D8R RX antenna drop my GPS sensitivity down enough to make HDOP sit above 3 all the time, again the remedy (once I knew it was the reason) was move the FrSky RX antennas away from the GPS receiver.
              On my copters I now use a GPS riser mount at the back of the copter, and fit the FPV and Mavlink antennas out at the front. Even better would be out front and hanging below the chassis. I don't have GPS issues anymore.
              Antenna separation is your friend when it comes to RF coupling and interference...
              • +1 for antennas separation. :-)
                When "less weak than usual" Tx are used, care of antennas and positioning is quite important.
                Mavlink 900 MHz by rfdesign 900 MHz modem gives up to 1 Watt output.
                (software power setting is great!)
                Video down link: 2.5W 1.3GHz Video Tx
                Main batteries telemetry (2.4GHz): Cell by cell telemetry values
                I believe in following each individual cell instead of total voltage.  (But that is just me LOL)
                And FRSky telemetry for electronics 5 Volts
                Henri
                Radio Modem Bundles - RFDesign
    • Hi,
      I by no means intend to respond instead of develpers who know best but I had same situation going on with telemetry screen showing 10-12 stas and low hdop but drone would not arm saying same 'need 3d fix'.
      this problem combined with very slow progress rate from 5-6 sats to 10 sats was all related to a high level of  EMI interference from the boscam transmitter 20cm away and FC BECs modules - so it took to put a solid copper plate under GPS unit for isolation and I look to do proper shielding now for GPS unit.
      After this shielding it locks into 12-14 sats in less than a minute - M8N unit - and never plays this #D lock error message again if it shows me proper HDOP in the telemetry.
      • @Paul: Thanks for your response.
        I don't power my fpv transmitter until I'm ready to go (otherwise it seems to get too hot) but one antenna from my FrSky D8R-XP is within about 10cm from the gps. I wonder if it's the telemetry transmitter that could be causing the problem?
        Strange thing is that this problem only started when I went to v3.3. Perhaps this version is checking for gps velocity problems that get reported as lacking a 3D fix? Anyway, I'll try to eliminate sources of interference to see if that will help.
          Roger,
          Yes, you're right on the money.  The EKF is doing additional checks beyond the GPS HDOP (I believe it checks the velocities coming out of the GPS agree with it's internal velocity estimates) and if those checks fail the pre-arm checks just display the GPS failure message.  We could change the message to be more accurate...
          • Thanks for your response, Randy.
            I'm sure you guys have more than enough on your plate right now so any enhancement to the error message content can certainly wait. This EKF stuff is all new (to me, at least) so it's been a learning experience.
        • this site keep dropping all input you type into it... it is annoying, after you typed a page or so of text.
          in my case EMI noise was the reason of both compass and GPS errors. I think a lot of GPS units are extremely sensitive, also, BECs may have switched working mode if you dropped from 5.3V down to 3.3V and they may produce more noise now.
