Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • Anyone else having this problem?
  • WARNING to TradHeli users:
    Do not attempt to fly AC3.3 until you hear otherwise from me.  I have not even bench tested it yet, let alone test flown it.  There are quite a lot of changes that have gone in that could be crash-o-matic for helicopters.
    AC3.3 release for Tradheli is likely to be delayed.
  • Upload Copter 3.3 to replace the 3.3 dev (debug bad accel health, but IMU2,Dropix, etc,etc...)
    Needed 3 upload to manage the 3.3 installation.
    Seems to work great, little windy day (5Km/h), auto-tune is great, same result on the PID as VP Kuisma and others but seems to work fine, the Quad is fun to fly, even if, for the moment, only one battery for auto-tune and PosHold and...RTL
    aggressive PosHold flight is great.
    I'm really happy with the Ardu, great work! far away the best!
  • I'm looking forward to trying the 'new and improved' Auto Tune; just finished a quad that's a bit overpowered and wobbles like a weeble on descent. 3.2.1 AT gave some crazy results.
  • This reply was deleted.
      Phil,
           The accel calibration values are stored in different eeprom locations for AC3.3 vs AC3.2.1 so as you switch between versions, you'll see the accel calibration values switch to what they were when you last calibrated the accels using that firmware version.  So once you've done the accel calibratoin for AC3.3, it should be safe to switch back to AC3.2.1 without having to re-do the accel calibration again.
      Phil,
      Yes, the max number of do-jump commands has been increased from 3 to 15 for the pixhawk boards in AC3.3-rc1 (and higher).
      Pomaroli,
      Aha, I had forgotten that there's a new CLI_ENABLE parameter that allows enabling/disabling the CLI and in AC3.3 it defaults to zero. Set it to "1" and the CLI is enabled again.
      This was done because we found that having the CLI enabled could cause problems for scripts or companion computers talking to the pixhawk as it rebooted. We could default the parameter to "1" but when Tridge and I discussed this we thought that most people were moving away from using the CLI anyway. As far as we know, there are no features in the CLI that can't be accessed through mavlink.
      • Hah - I've just ordered a pixhawk because I thought my board was going bad because I couldn't get into the cli (and had a few other intermittent connectivity issues which now appear unrelated!).
          @pomaroli,
          Ah, ok, that's because we've removed the log download method from the cli.  So the only way to do it is via MAVLink.  The MP's flight data screen has a dataflash tab on the bottom left.  This is a more reliable way to download logs in any case it has checks that prevent corruption in the data on the serial line.
      Pomaroli,
      Thanks for the report.  You're right that we don't seem to be able to get into the cli menu.  I'll have a look.
