Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
A question about the Storm32 serial setup:
For me it seems to be not possible to setup manual RC control as done with mavlink. Do I do anything wrong or is it still not supported? I am using storm firmware 0.82e.
3.3RC7_letzterStand.param
letzter Stand.cfg
Gregmaan,
So it looks like it's setup to use the SToRM32 serial protocol and you're planning on controlling the mount's tilt with the transmitter's channel 11 and the pan with the transmitter's channel 6. Looks like you've probably followed the instructions on the wiki because the SERIAL2 baud and protocol look to be set correctly.
I guess you're saying that the gimbal doesn't move when you move channel 6 and 11 on the transmitter?
Randy, I started separate thread for that question -
http://diydrones.com/forum/topics/need-step-by-step-guide-for-storm...
if you`ll have time could you pls respond there so we would not pollute this thread with storm32 stuff?
Paul,
Ah, thank you very much for that. As mentioned over there, I think the best idea is to try and get either the MAVLink or Serial protocols working instead of introducing a 3rd protocol to control the gimbal! Two protocols is surely enough!
I also got this board and so far unable to make it talk with AUAV board.
I know storm32 board can be also connected via SBUS - how can it be done exactly if serial connection does not work out?
Also, what and how can be done to make serial 4 port to appear? I understand serial 5 is by default mapped into output, but can be swapped by serial4?
Yes thats exactly my problem. Sorry for my poor explain
What would also be nice is to have additional channels in sbus out. For a hex, I only have 2 channels not tied to escape outputs. Channel 8 out easily links with my camera pitch control, but I also need a pass through for my camera shutter. If I am using the rc in channel 7 as an auto tune trigger, but not using the channel 7 output, is there a way to pass, say, channel rc 10 in out to channel 7 so that I can control channels within the current sbus out limitations?
I guess I can use channel 7 as a pass through and one of the higher channels as an auto tune trigger. Not ideal but it will work.
What is the reason for this???? During the flight I have always between 16 and 19 sats and HDop until 1.1
I forgot the logs:
2015-06-27 16-10-06.zip
