Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • ok~thank you very much!
  • amending
    • I'm trying to set up a quad to use the LG function. I have set Ch 8 to Landing Gear in Extended Tuning. Do I need to change RC8_FUNCTION to 29 in the FPL or leave it as 0 as it is? What 'Hawk output do I connect the LG servo to please?
      • Its all explained here: Landing Gear
        In short:
        1) Set Ch7/8 Opt to Landing gear if you want manual control
        2) For the servo use AUX1-4, ie RC9-12, so set the channel which you use to 29, ie if using AUX1 set RC9_FUNCTION to 29 (Landing gear)
        3) If you need to, you can adjust the PWM for gear up/down with LGR_SERVO_DEPLOY/RTRACT
        It's working great.
        • Thanks, I had read that. Clearly I'm not explaining it well. I couldn't understand the relationship between the channel number set in the Extended Tuning screen and the Aux/RC number in the FPL. You can set either Ch 7 or 8 to Landing gear and any of grouping Aux 1-4/ RC9-12, but what makes the link between the two sets of information?
            I've also asked MichaelO to create a setup page.
            • Thank you both for the information. My failing was being in the OpenTx paradigm as I was searching for a way to define which of the two input choices went with which of the four possible outputs. Happily I didn't need to worry as the firmware sorts that out for me.
              • Yes, the way this works basically, is that there's some logic which handles the landing gear, which is looking at the state of an internal switch, as well as a few auto-modes, such as RTL, etc.  That internal switch is manually controlled by whichever RC Input you choose.
                The controller decides if the gear should be up or down, based on a blend between the state of the switch, and the flight state of the vehicle (forced down when landing).  Then it publishes a LG output state to the RC Output controller.  Like "Hey, whoever is controlling landing gear, go down!"
                The RC Output controller checks to see which channels are defined as controlling the LG, and makes them act accordingly.
                In fact, I think you could have more than one output channel set to LG, and it would just work.  So you could have two LG controllers without using a Y-splitter if you wanted.  (You cannot have to LG switch inputs however).
          • Mike,
            In the Extended Tuning screen you are setting your input channel for manual gear up/down.
            With RCX_FUNCTION you are telling to the FW on which AUX channel your gear servo is connected, ie your output channel.
            The fw is using that info to manipulate your gear either in automated mode (Land, RTL) or in manual mode with Ch7/8.
            A little different to setup then the gimbal, which setup screen has input/output channels, but it works in a similar way.
            HTH
  • Have others experienced a lot of noise in Rcout and increased vibration levels on rc7?  I'm used to seeing .5-1 vibration levels vs 2+.  I opened a few logs pre-rc6 and the data looks completely different. Mechanically only the props changed and new case for the AUAV-X2, but I had these props on before and didn't exhibit these high noise levels. The wiring for the new case was not removed from the board, basically a transplant; new 3DR vib foam was used.
      Today after AT I took it back up and played with Follow Me Circle, then Face Me, and GCS failsafe kicked in (no audible warning), it went into what I assumed was RTL and just kind of floated and did not gain much altitude, so switched to stab and throttled up (when it doubt, go UP), then switched to RTL. It did not move into position to land but kept moving away slowly. I then switched to stab/poshold and it seemed ok, so landed.
    I'm wondering if there is an issue with Tower conflicting with Pixhawk. This odd behavior is a first. Tower is also giving false audible voltage %.
    There were no GPS glitches that I could find. Rcout is extremely noisy. Vibration levels higher than normal.
    Link to file (it's 90mb, includes AT and rest of flights) for anyone interested
    http://www.mediafire.com/download/o7b4v1nja0kyh8i/2015-06-30_20-10-...
    Hover after AT and switch to APC MR props was pretty good.
    https://youtu.be/S0mTA68dKv0
