Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      Alp,
      Ah yes, thanks for the reminder.  It's because we renamed those parameters between AC3.2.1 and AC3.3.  I'll ask MichaelO (and other GCSs to update the names on their side).  thanks!
      • You are welcome Randy.
        What is the meaning of "FF" Settings? Force Feedback? :)
          Alp,
          That's "feed-forward".  It's probably better explained on wikipedia but it's used to reduce the reaction time in the control loops.
  • Hi Guys,
    Can anyone help me out?  I still have three different Pixhawks (Original 3DR) with various setups that all error on arming.  Any advice would be MUCH appreciated!!!
    I have recalibrated, loaded new firmware, erased the board, checked GPS (Reconfigured with uCenter), set all params to default etc., disconnected all external equipment, loaded custom code so I can check what is causing the fault but I get stuck at bad position estimate.
    So far I have noticed that all of my boards report the following (which seems to be different from the working systems out there):
    EKF1> PN, PE both = 0
    EKF2>Ratio = 50 (Not moving)
    EKF2>MX, MY,MZ all = 0
    I am guessing that this is what is leading to some of the innovations in EKF3 also being 0 (IVN, INE, IVD).
    All of the RAW IMU, MAG data seems OK to me.  Even the FFT graphs in MP seem to show no problems but I am not sure what the sample rates should be, so I am guessing.
    GPS is LEA-6H 3DR model.
    I have been tyring to figure this out on my own but would really appreciate some guidance.  Attached is a log using the latest build and Quad sitting on the ground, not moving but refusing to arm without reporting EKF Error and going into failsafe.
    On 3.2.1 all of my machines are fine.  I realise that this is Beta firmware but I thought it might be helpful to see some info from a non working system.  I am pretty sure that there are no hardware related issues but either I have stuffed up some settings on three different configurations or there is a problem with 3.3 and my gear that is different to everyone else's.
    I realise this build is very beta and I am not complaining, just trying to offer some more data to the Dev's and also trying to learn how to fix this issue at the same time!
    2015-07-03 11-23-59 EKF Error Lockout.bin
      Alex,
      From a look at the GPS messages the number of satellites is quite low - it peaks at 9 but spends a significant amount of time at 6.  I guess this is the cause of the bad position message.
      • Thanks for the reply.  Much appreciated as is all of the work you guys do.
        I will try again with more sats and let you know.
        Is it normal to get the EKF Failsafe with low Sat count/High PDOP? I seem to get this on all my machines and once triggered the EFK error will not go away even with 10-12 satellites before arming.
  • Hello,
    I noticed my minimosd quit displaying data once I upgraded to 3.3 on my tricopter.  I'm running version R800 minimosd extra.  I'm assuming there is some incompatibility now.  Which version of software should I be using with the minimosd to work with 3.3 software on my pixhawk.
    Thank you
    • Mine quit working w/ 3.3, too.  Also r800 extra.  Y cable on telem1 w/ radio.
      I spent a couple days on it, quadruple checking all the settings outlined in the various wiki's w/ no luck.  It did work before 3.3.
      But I'm also having an issue where my sr1 parameters do not save, ever since 3.3, and maybe that is why the OSD doesn't work.
      If it's working for some people though, we must be doing something wrong.. (and the wiki's must be wrong or incomplete)
    • Minimosd definetely works with all 3.3 rc versions. Works on my system on rc5 and rc7.
      What may be an issue is a situation where this serial port does not automatically start telemetry statistics so that is why minimosd shows nothing.
      • Hi Paul,
        Thank you for the reply.  Are you also running R800 software on minimosd?  Of course I may be missing a setting in the pixhawk for the OSD to work correctly.  My serial port is set for mavlink output and 57600 baud rate.
        Before 3.3 I did have problems with sometimes the minimosd not displaying messages.  I would have to reset everything and eventually things would work.  It's different now.
