Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • Aha! I figured it was something like that. I will go plug the tricopter in and see what that does. Thanks!
    • Maybe something broke here?
      https://github.com/diydrones/ardupilot/commit/b8181b6b90fb2a5b5fbfa...
      This is the only mayor rework that happened with the tricopter code since April and has to do with the servo.
      • Strange, I didn't even have the tricopter yet in April, and I flashed the latest version sometime in early June and that was the version that worked.
  • The Storm32 serial protocol did not work for me. Is there a special firmware on the storm required?
    I tested it with 0.80 and 0.82.
    http://diydrones.com/forum/topics/copter-3-3-beta-testing?id=705844...
    Folowed the wiki for setup. But I can´t control it neither with MP nor with manual RC control.
    I did not get any answer on my request on the bottom of page 160 (link).
    There are also some additional requirements:
    Passthrough of 2 PWM channels to the storm output lines via serial (control of camera).
    Using the Storm link feature as 2. IMU over serial.
    Cheers Gregor
      Gregmaan,
      I've tested the SToRM32 gimbal serial interface with SToRM32 version 0.70 firmware and confirmed that it works.  I haven't tested it with 0.80 or 0.82.  It's possible the protocol has changed or that something was missed during the configuration.
      The additional requests are probably on the to-do list but certainly won't make it into AC3.3.
      • Hi Randy,
        0.70 is a big step behind 0.80 or 0.82e (pan/yaw axis problems).
        I will check if 0.70 is running for me (maybe a configuration issue from my side).
        Hopefully there is a chance to get the 0.80 and above running with AC 3.3
        • Please keep us up to date if you can find any improvement with 0.80 or higher. Thx
      • Randy could you at least take a look at this issue:
        https://github.com/diydrones/ardupilot/issues/2426
        Seems very serious. I'm sure there will be a lot of people using the Storm32 controller with 3.3 since there is native support for it to some extent, but it would be sad to have a lot of people with burned out gimbal motors or broken cameras from that bug :(
        • I also would appreciate a working SToRM32 controller with pixhawk via serial!
  • Tarot 680 pro frame.
    13x5.5 cf
    blheli damped light esc
    3.3 RC7 only pitch and roll autotune.
    I can ear motor vibrations from the resulting autotune and hexa is twitchy around middle stick, mostly on the roll. I reduced resulting values 15% afterwards. The high vibs seam to go away (D to high?? or P ??  ) but the middle stick movement gives twitchy result.
    My main problem is around middle stick. The very beginning of stick input and the copter is not smooth. On higher angles it does look locked and stable, just not on the very beginning of stick input. Best I can describe is wobbles. Slow and little roll or pitch inputs and the hexa wobbles just a bit.
    Any suggestions ? Lower autotune_aggr form 0.1 ? higher than 0.1 ? reduce all autotune values by 25 % ? Does anyone see anything wrong on my log ?
     -> Autotune Log  -/p>
    Thank you
