Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
                • full parameters list -> RC7 out -> rev change the number to -1.
                  done.
                  • hm.... something weird...
                    will try to test tonight......
                  • Right, I got that. But no, not done. What I'm saying is that in AC3.3rc7, the behavior of the tri is unchanged regardless of whether this parameter is set to 1 or -1. That's what those logs I posted are showing.
          • nope, talking about different thing. full parameters list -> RC7 output ->rev -> -1/1
            been flying tricopters with AC code long enough to tell it works very good, the only thing which didn't ever work for me properly is autotune. it worked OK up to 3.1.5, later revisions changed it to absolutely useless. tried on RCE and my own 6s powered tri.
            • Likewise. I don't know what's going on all of a sudden. Like I said before, if I flash 3.2.1 on this thing, it works fine. Just confirmed that this morning after posting my logs. But if I put 3.3RC7 in, whirling death blossom.
      • Roger, figured that's what you meant.
        • It was actually 0 and 1 until randy changed it, which made more sense from the name of the parameter YAW_SV_REV(erse)  "true" 1, "false" 0, i missed the later commit where he did -1 and 1.
    • What GCS are you using? Have you tried a different one? I would think more copter would be having problems with such a basic setting. Maybe it is the GCS that isn't properly doing what you expect. I noticed in a quick Google search that something similar had been a problem before.  Just a thought...
      • I'm primarily using APM Planner 2 for the Mac. I was having connection issues on my laptop, which has been pretty regular and I'm not the only one who has had issues on the Mac version of APM Planner 2 for some time now over several versions (sometimes it doesn't want to connect via telemetry, sometimes USB is having a bad weiner day, and between both of my computers sometimes it works sometimes it doesn't), so I went to my desktop. I also tried APM Planner 2 for PC (same computer, different partition), as well as APM Planner 1.whatever the latest version is for PC. I don't have an Android tablet, so I can't try changing the settings that way, but I don't think the Android GCSs give you that level of control, anyway. I don't mess around with QGroundControl or any of the other GCSs, either.
        Anyway, yes, I have tried different computers and version to confirm that the setting was in fact changing (and even reflashed the board several times). The log files I posted were a clean reset to defaults reflash (after flashing Rover to make sure it REALLY nuked all the settings), then I set the yaw servo to reversed (as it should be) to get the first log, THEN I went back and set it to Normal (as it comes from a clean reflash). So I know the settings are in fact changing.
    • Yeah, try setting YAW_SV_REV to 1. Now there is also YAW_SV_MIN, YAW_SV_TRIM, and YAW_SV_MAX for min, center and max PWM output to the servo as well.
      Yoda_TPM_RotS.png?width=100
sam liked Jimmy Oliver's profile
Aug 25
Mike Whitney liked Mike Whitney's profile
Jul 19
Abdulatif Tlaib liked Ryan's profile
Jun 24
