Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
The GPS glitch behavior you describe is quite different than what i saw this week, which Randy graciously pointed out were caused bad parameter settings. I'm still investigating how they got set to 0.
I used to have frequent problems with GPS glitches. I moved the GPS up and farther away from the rest of the electronics and haven't had a single glitch since (perhaps 40 flights).
--Brad
By the way, in AC3.4 we can get rid of much of the twitch as it switches GPSs. We just need to reset the target position of the copter by the position difference of the two GPS. In Loiter the pilot will hopefully not notice any twitch. In Auto you might see a shift as it realizes it's off the desired line but it'll be much better than now.
Log files - https://www.dropbox.com/sh/qb1quw427ak72hf/AADLxYfHgvbjQBSp8WbIRMkB...
I must be missing something because I can't think why the highest vibrations are not now in the horizontal axes. Do most people have similar values for all 3 axes or could the Z axis be more sensitive?
It's normal for the Z-axis (vertical) to have higher vibrations. We think it's because the vibrations are largely caused by the propeller passing over the arms of the vehicle.
I'm reasonably confident the reporting is correct. There's not much too it really.
In the log https://www.dropbox.com/sh/qb1quw427ak72hf/AADLxYfHgvbjQBSp8WbIRMkB... the first half shows high VibeY as it is on its side and then it corrects its attitude showing high VibeZ ending with a 'crash' error. No harm as it was just being suspended on its side.
Philip,
The vibration calculation code is here and it doesn't have any special code that should affect the vibration levels based on orientation as far as I can tell. From the logs it appears the Z-axis vibrations are always the highest regardless of orientation although I can also see the X, Y are higher in the "on right side" log - that could be environmental though perhaps.
I get much higher reported on the Z-axis and have never had a problem. I'm not convinced the reporting is accurrate ...
Flying 3.3 rc8 on a 250 class racer. Just got it built. I use a 1300mah 3 cell battery.
I am trying to do an autotune. Auto tune starts and gets past the autotune of the roll and into the pitch autotune. I only get about 5 minutes of flight time, and the autotune doesnt finish before I run out of battery.
Is it possible to do a 3 step autotune? i.e. during the first autotune session it will tune the roll. Then you land and save those pids, then you switch to pitch autotune, land save those pids and finally do a Yaw autotune?
I've shut off everything I can to get max flight time, and I just cant get the autotune finished before I run out of batteries.
Thanks for your help!
Scott...
Nevermind I found it :)
There’s also a new AUTOTUNE_AXES parameter which can be used to enable just a single axis:
7 = do all axis
1 = roll only
2 = pitch only
4 = yaw only
