Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • Randy,
        Very good job!!!... really thanks.
        Regards
  • HI Devs,
    Has something changed with MAVLINK from 3.2.1? I have a an app that works perfectly on an APM3.2.1, but on my PIXHAWK running 3.3rc8 it doesn't get the correct descriptions for the flight modes; although it will still switch them.
    Any thoughts?
    Cheers, Mike
  • I wanted to report that after using OF, the pixhawk refused to acknowledge the existence of a GPS device, as well as refused to output FRsky Telem on SERIAL_2. Had to reflash to 3.2.1 for normal, non-OF flight. Also, it seems that the ARM warnings (Accel, gyro, compass health) are all triggering for no apparent reason, even after re-calibrations. I will attempt to post dataflash logs and telem logs later. Just be wary that there are oddities after using Optical Flow.
    • could this be the issue with the telemetry?
      Austin,
      For the GPS issue, as part of setting up the optical flow sensor did you set the EKF_GPS_TYPE parameter?  If yes, maybe setting it back to "0" might get it working again.
      • I had changed the EKF_GPS_TYPE parameter back to 0. It failed to even show stats about the GPS, i.e. Sats, hdop, etc.... After that didn't work, I actually went one step further and used a beta param file I saved from before I configured the OF, when the GPS was working, and reloaded that. No dice. Even reflashing the firmware to the same beta firmware didn't help. The problem only resolved when I reflashed to 3.2.1. I will see if I can get the logs for you.
        • same thing happens to me when i use the 3.3 beta on PX4FMU  + PX4IO. it didnt see the attached GPS but resolved when i use 3.2.1 firmware.
  • 3702066209?profile=originalWay OT sorry. Couldn't resit. Still hoping for 'boat mode'.
      "boat mode" coming soon! It will calibrate copter (and Solo gimbal) on moving vehicle.  Dynamic home location (for moving platform) and GPS position-hold loiter optionally replaced by alt-hold, to ensure that the vehicle doesn't zoom "backwards" trying to hold a static position while you're on a moving vessel.
      • Although I am sure you probably are aware of this already, here are some guys who have already implemented "Boat Mode" - http://mikrokopter.altigator.com/boat-mode-take-off-from-a-boat-n-3...
        From what I can tell it works basically like this...
        1. You arm you bird on a nice level surface on the mainland.
        2. You hop on your boat, switch to "boat mode" - which loads the last values of the gyros, i.e. the ones you got in step 1.
        3. You take off in Alt-hold - for obvious reasons.  Switch to loiter up in the air if you want.
        Boat mode: take off from a boat
        Sometimes drone users wish to be able taking off from a boat. Even for very large ships, a boat is somehow always moving. Before starting to fly…
Gremsy liked Gremsy's profile
Mar 12
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
