Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • altitude prioritizing would be well suited for 'boat mode' fyi. Lest we end up with the perfect vid shot right into the drink.
      • Sure, why not. Probably good logic would be to gain back to original altitude after detection of an altitude sudden drop and if if goes up and down within a meter of so, it is not a big deal, as long as it done smooth.
    • Did you check your vibs? I have that problem with vibs in one cuad, I hope the y ones do that but not shure, what shure is I have that problem when vibs aren't constant.
  • My current setup is a tbs discovery frame with stock dji arms, 1045 carbon composite props. What is the recommended value for Aggr? I would like to set it before trying autotune. Thanks in advance!
  • Hi devs, I'm not able to do autotune on rc7 without sending my quad wobbling to the ground. First few steps on roll axis seem normal but then it looks like it gets a diagonal step and becomes unstable. Is this maybe a hardware issue? 15inch props, 470kv motors. Using default parameters except aggr 0.05, but same problem with aggr 0.1. The log is attached.
    2015-07-16 22-11-12.bin
      Hi Arni,
      Sorry for the delay in my reply. This is almost certainly caused by poor starting tune. You are getting an oscillation that is coupled between the two axis. The scary part is it looks like it is getting started by a sync issue in your front right motor.
      You may be wise to tune this copter manually until you are confident you don't have ESC sync issues.
      As far as I can see your Arducopter setup looks sensible.
      • Hi leonardthall,
        I'm trying to learn reading the logs, and I'm wondering: what info in this one shows that there is a sync issue?
        Or even better, how can I now that one of the motors has a problem, sync or something else?
        Thx
          Hi Igor,
          I look at a couple of things but mainly I am looking for movement in the copter that doesn't match the motor outputs. This is pretty clear during autotune because I know that before each twitch the copter is level and not moving much. Then it gets commanded to move in one axis only. This is then followed by a movement back to level. So if I see any movement other than the single axis I look for signs of a poor CG or a motor sync issue.
          Now I go to looking at the motor outputs. The symptom of poor CG I am looking for is a consistent mismatch of motors, generally forward and aft motors.
          If I don't see this then I look at the time the copter moved from it's desired axis twitch and look at the motor outputs. Generally I see a significant difference between the last twitch and the previous twitches (generally I have been given a crash or near crash so the autotune stopped after the twitch with the problem). The normal twitches show a clear motor output to cause the copter to accelerate in the desired axis. The problem twitch generally shows a very different response as the copter tries to level itself. It is normal to see the motor with the sync problem going to maximum but that arm still dropping.
          • That's great info! Thank you!  I wish there was more like this in the wiki
              Hi Richard,
              Yeh I agree, but it is hard to do. It took me 10 minutes to do that small block of text, but it would take me an hour or more to write it up in enough detail for the wiki. Then we would need to do that for each particular log analysis.
              The Wiki is constantly traded off against improving the code. If people would like to summarize some of these things and provide text and pictures to Randy we might be able to cover a lot more ground in the Wiki.
              On that note, thanks to everybody that is helping out answering questions here!!!!
