Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      It looks like the WPNAV_SPEED and  WPNAV_LOIT_SPEED have been set to zero somehow.
      By the way, the .bin files are actually better to provide than the .log files.  The .log files are bigger and they're converted from the .bin files by the MP on the machine that does the download.  It looks like your MP might be slightly out of date so it's been unable to convert the .log file completely correctly so for example the flight mode strings are not provided, I can't see the flight code version that's being used either.  The TUNE variable is strangely missing as well - so I can't see if it was the ch6 tuning that is the cause of the zero WPNAV_SPEED param value.
      So, although the analysis is not complete, I'm pretty sure that this WPNAV_SPEED is the problem.
      • Thanks Randy.  I'll send the .bin files next time.  I was using the .log files, converted via apmplanner 2.0.17-58 with a quick and dirty awk script to find the GPS gaps.  I guess I should do a fresh conversion using the latest missionplanner before I trust the data then.  I routinely use apmplanner, missionplanner, and tower to change parameters.  I don't remember which GS I used this weekend when I adjusted my YAW PIDS a bit (The autotune left it a little sloppy for 2D gimbal use), but I didn't change the WPNAV*SPEED parameters and I can't see why anything would change them randomly.  I'll compare to my last saved parameters and see if anything else changed!  Any idea how they could get set to zero without explicit action on my part?
        Thanks!
        --Brad
          Brad,
          It sounds like an issue in one of the GCSs.  I'd guess the mostly likely culprit is AP2 followed by Tower but that's purely a guess based on how much testing and how many users the platforms get.  It could be MP.  If you can reproduce it or narrow down which GCS did it then we should file a bug report in the issues list for the offending GCS.
      Brad,
      Thanks for the report.  Do you have a dataflash log?  If it loses GPS it should enter pilot-controlled Land so it should descend slowly but the pilot should have control over the roll and pitch as if in AltHold.
      Tower may report "Lost GPS" when the GPS goes into a new state, "4" which means it has SBAS.  This is actually very good quality signal but Tower may not recognise that state yet.  I've noticed this once I think so we need to get the Tower guys to sort that out before AC3.3 goes out.
      • Randy,
        Thanks for the quick response.  I thought I had it figured out, but now I'm just confused.  :-)
        I do see the GPS status changing from 3 to 4 about the time I might have heard one of the lost gps messages.  But I do also see a big gap of GPS reports in one of the logs, but now, i realize the gap is in the flight where it started out bad and the flight where it went bad later doesn't show a gap.
        --Brad
        I've taken the liberty of sharing a link to the logs via google drive to your email.  I hope that's OK.
  • Yesterday, I tested this new release (rc8) , in Stabilise, Posholt, AltHold, etc….
    And I’m surprised with results. Really, really good (for me J ).
    Looks like the commands are more “precise”, in stabilize looks like AltHold….
    Telemetry over 4g works fine too with Mission Planner.
    My motors are very “strong” but I never flew with so strong wind,
    attached only I short video in stabilize mode….very good flight even with strong wind.
    Congratulations, this new release looks very good
    I’m running this new release with Navio+ board from Emlid, really good.
    https://www.youtube.com/watch?feature=player_embedded&v=8rd4Mmn...
      Robert,
      Nice to see the Linux boards (NAVIO+) being tested here.  There's been a lot of improvements in the Linux code over the past couple of months.  Besides the contributions from the Emlid and ErleBrain teams Intel (a member of DroneCode) has one of their open source developers helping us quite a bit now.  Glad it's paying off!
      • Randy,
        Very good job!!!... really thanks.
        Regards
  • HI Devs,
    Has something changed with MAVLINK from 3.2.1? I have a an app that works perfectly on an APM3.2.1, but on my PIXHAWK running 3.3rc8 it doesn't get the correct descriptions for the flight modes; although it will still switch them.
    Any thoughts?
    Cheers, Mike
  • I wanted to report that after using OF, the pixhawk refused to acknowledge the existence of a GPS device, as well as refused to output FRsky Telem on SERIAL_2. Had to reflash to 3.2.1 for normal, non-OF flight. Also, it seems that the ARM warnings (Accel, gyro, compass health) are all triggering for no apparent reason, even after re-calibrations. I will attempt to post dataflash logs and telem logs later. Just be wary that there are oddities after using Optical Flow.
