Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          • Hi Leonardt,
            maybe overshooting is the right word for what I think it does? Or in other words maybe too sensitive to outer influence?
              Hi Gregmaan,
              Sorry but you will really need to go into detail if you want me to understand what you are seeing.
  • Randy or Leonard,
    What are the preferred settings for logging in 3.3-rc10 with a PH?
    And what can be done to get auto analysis to work with this build?
    • auto analysis has to be fixed in mission planner. It's something Mr Osborne and whoever else is working with him needs to address, but I'm sure, just like with Kev's Log Analyzer, with things being such a moving target right now we are going to have to wait until the final hits and then they can catch up :)
      • Craig,
        Thanks for the reply about the AA.
        How about logging settings?
  • I tested AC 3.3 RC10. This is a very stable release.
    And I wanted to draw attention to the following:
    1. Upload the firmware to Pixhawk AC 3.3 RC10 will be better if the first from AC 3.3 RC 9 down to AC 3.2.1, and then up to the AC 3.3 RC10
    2. Then need to check all the major parameters.
     And they are need to be rewritten.
    2. I do not use the automatic tuning. Better to use the manual settings for test flights.
    3. Very important buttons 'Calibrate Level" It is advisable to use prior to each flight.
    4. I'd like to ask to make the possibility of setting on or off the Audio Indications in auto mode. I can set the switch, but it is better to do it programmatically.
    My first the test here:
    Stabilize mode :  https://www.youtube.com/watch?v=meYPmOkk6yM
    Auto mode :  https://www.youtube.com/watch?v=UXIEqR_i45k
    • 1. Upload the firmware to Pixhawk AC 3.3 RC10 will be better if the first from AC 3.3 RC 9 down to AC 3.2.1, and then up to the AC 3.3 RC10
      As one fellow reminded me lately, this will do the reset as well:
      If I manually go in and change the SYSID_SW_MREV from 120 to 0, push the write params button and then disconnect/reconnect the parameters are restored to their defaults
      Saves some time;-)
      • Thanks, I'll try it.
      • Why not just hit the Default button in Mission Planner?  The one on the advanced Param or tree view page.
        I thought this also put all values to default.
        On point 3. Calibrate Level  I founbd it best to do this once, when I can be sure to make the frame level.  Then NOT to redo the calibration unless thge Pixhawk has moved in relation to the frame.
        On another frotn, with the EKF parameters which is the best to adjust the weighting of the GPS to IMU?  I have tried adjusting the Noise BIAS params and this seems to work.  Is this the best place to do this?
        I can see that they are already weighted towards the accels so is it better to increace this wieghting or change the GPS glitch params so that the GPS readings have to be tighter?
        Overall I have found the latest relaease to be very solid and I am just wanting to fine tune a bit.  Thanks for all of the fantastic work.
        • Sorry about all of the typo's and bad spelling!!  It seems that I must have had a few moments of dyslexia.
DIY Robocars via Twitter
RT @a1k0n: Did I get rid of hand-tuned parameters? Yes. Am I still hand-tuning more parameters? Also yes. I have a few knobs to address the…
5 hours ago
RT @a1k0n: I'm not going to spoil it, but (after charging the battery) this works way better than it has any right to. The car is now faste…
5 hours ago
11 hours ago
Saturday
Saturday
Saturday
Friday
Thursday
Sep 11
Sep 10
Sep 10
Sep 10
Aug 28
Aug 24
Jul 4
Jul 4
