Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Many thank's Alex, It's possible that pins are changed, I have an old 3DR Pmodule 3-4S and didn't check that, I have to invert nearly all when I change the APM 2,5 to Pixhawk (chinnese) I have the 6s PM that's arrive with the Pix, I'm going to change pins and if doesn't work I change the PM, many thank's to discover, I didn't take care of curr because I had an external alarm reading batt and looks good when I land so I'm not going to discover the issue for my oun.
Thank's for the tips, arming in Poshold it's a good idea, I almost time fly in pos hold so check looks interesting for me.
Does anyone know why Rate P and I are always the same when autotuning in 3.3? Seems a bit strange. Trying to sort out why my unit is shaking on takeoff, but flies well otherwise. Maybe not related, but still seems odd P and I are always the same.
Hi Shaun,
This is because autotune sets them to be equal. This is based on the time constant the average pilot expects to see.
Am I the only one that didn't know that?
No ;)
Yes ;)
RC11 flies very well. I had frequent EKF issues, all resolved now. Thank you!
I have not seen any info regarding DO_MOUNT_CONTROL other than mentioning it in the wiki. I have wanted to use this for some time now, so I thought I would post a video showing my results. I did not spend a lot of time planning the mission and its not the greatest video, but maybe it will help someone. I am flying a stock IRIS+ with a tarot 2d gimbal, so pitch will be the only variable. In mission planner my gimbal is restricted to move between 0 deg and -90 deg. If using a different gimbal, check the gimbal set up page to know the limits for this command. I initially tried a pitch setting of 20, and since that was out of the range of 0 to -90, nothing happened. When I figured out pitching down should be a negative number, it worked great. At the first waypoint the camera goes to -20 deg, followed by -25, -30, -35, and -40. I included the waypoint file is case anyone wanted details.
https://youtu.be/bnjXxMpqgKI?t=43s
I'll be using -30. Here's a large road project near me. This video ends showing a transition from DO_MOUNT command to ROI and back to DO_MOUNT.
https://youtu.be/SVp7MN3sTg4
mount test.txt
Thanks for testing, nice video!
Thanks for developing!
Copter-3.3-rc12 is now available through the Mission Planner's beta firmwares link.
Desperately hoping that this is the final release candidate. We received some complaints from others on the dev team that they were seeing a "Compass Variance" pre-arm failure which they could never get rid of without power-cycling the board so -rc12 has a change just for this one issue.
If all goes well we will do the "soft release" of Copter-3.3 no later than next Tuesday.
