Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • Not natively. I believe there are options using external "translators" based on Arduino's and/or Teensy's that convert Mavlink telemetry to HOTT.
  • This reply was deleted.
      Hi Kurt,
      While I have not used the same module you have, I do use the frsky D telemetry on all my copters and there are absolutely no problems on the pixhawk side for the D type telemetry. I also have a couple of friends using the same system and none of them have seen any problems with the pixhawk frsky telemetry either.
      Sorry I can't be more help.
      • I use the direct method as you describe (see photo), but sending it to a FrySKy X8R. It works great for me, I simply set up a screen using the default values as 'discovered'. Currently I am playing with an pre 2.1 LUA script and updating the Telemetry ID's, again, so far so good.
        This a DIY version of the FUL-1 for Smart ports...Cheap as chips!
        https://goo.gl/photos/6ghdRSGUbnu13FdCA
        New photo
      • Perhaps the issue is not on 3.3 but OpenTX 2.1.x has completely revamped the telemetry system. Part of that revamping is that no sensors are pre-defined, and must be "discovered" on the fly using the telemetry screens for each model.
        3702720612?profile=original
          • If you mention the answer you got at RCGroups, forget it.
            I have telemetry running on 3.3RC12 on every port I choose, (Telem1,Telem2,Serial4) as long I have it configured to do that (SERIALx_PROTOCOL), which in my case I have it as 1 because my FrSKy telemetry system is based on the Teensy.
  • I am using RC 10 still and had a odd bug after an Auto mission. The mission went ok, but after landing and automatically disarming I could not rearm in Althld. After the first mission while changing modes and trying to rearm the quad finally desided to rearm after 2 mins of setting.
    After the second mission I could not get a rearm at all even after several minutes.
    MP only showed a "Disarmed" message on screen.
    I will have to wait until this evening to review the logs.
    I was wondering it this had happened to others as well.
