Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • Thanks Fnoop Dogg.  Yes, it would be useful to have the wiki updated to clarify the functionality and under what circumstances the auto-deploy is activated - it will save some head scratching.  I'll test it with RTL, but I think I'll try it with my camera and gimbal off at first  ;-)  Cheers!
    Noticed a couple things using the latest 3.3 rc1x, I'm flying a small carbon tricopter with the AUAV-X1 flight controller.
    1) ResetToArmedYaw (CH7/8 option) doesn't work, info from a search reveals it has never worked, is there a plan to get this working? (it's not quite the same as Simple mode)
    2) Autotune weirdly doesn't seem to work for me, I've set AUTOTUNE_AXES to 4 (to tune yaw only) but when in ALT_HOLD and I switch CH7 (Autotune) to high nothing happens. Is this tricopter specific?
    3) The loss of altitude problem in ALT_HOLD forward flight is very noticeable on this airframe (not in this log), however to clarify this and to hopefully add to it's understanding, there is no loss of altitude DURING the actual forward flight, however the loss and recovery only occurs AFTER the pitch stick is released and the copter is drifting forward while level, it's almost as if the altitude controller can't catch up properly or overreacts to the sudden change in attitude?
    Log attached (two attempts to autotune and one to ResetToArmedYaw)
    3702104118?profile=original
    2015-10-04 10-06-33.log
    https://storage.ning.com/topology/rest/1.0/file/get/3702104051?profile=original
      Hi Graham,
      The reason Autotune won't start is because you have not centred your throttle stick. You are asking for an altitude change and it is pausing auto tune until you centre the throttle stick.
        Thanks Leonard, what value center throttle is it waiting for? My throttle in was 1583 for the first one, is it looking for exactly 1500?
          Had lowered the throttle deadzone so center throttle was more elusive than necessary, thanks again.
  • I've got a lot of kinks out of my setup now.
    3.3 and Tower beta release play very nicely together. Tested 'Follow Me' this afternoon. and got the Hero4 Gopro slung on the FeiYu 3d Mini gimbal for the first time. Just downloading the video to see how it handled things but first impressions are really good.
    Muppet here was testing circle mode and the vehicle just clipped a tree. Explosion of leaves and twigs, airframe tumbled out of tree at least 90 degrees rolled over, lost about 2 metres altitude. Flattened out and ........... stabilized. No harm done!
    Now if I can get Airborne Projects to update their Mavlink and the Lua Scripts I can go back up to OpenTx 2.1.3!
  • AC 3.3 RC12 - I'm doing some advanced tuning to certain parameters and need guidance on what values I should use for the following- I searched around and could not find guidance on how to tune these parameters for my specific build:
    MOT_THST_EXPO (default is 0.65)
    MOT_THST_BAT_MAX (default is 0 - do I just put 4.2 x 6S cell count = 25.2? )
    MOT_THST_BAT_MIN (default is 0 - do i just put 3.3 x 6S cell count = 19.8? )
    MOT_THR_MIX_MAX  (default is 0.5)
    MOT_THR_MIX_MIN  (default is 0.1)
    MOT_YAW_HEADROOM (default is 200)
    Quad specs: 6S lipo, 17x5.5 props, 5010-14 360kv, 2480 AUW, 30% THR_MID
      Hi Kurt,
      That looks very good. In order to do better than that you would need to give me the throttle curve of that particular propeller, motor, esc combination.
      • Leonard- i ran a quick ecalc, would this curve data help?  my flight logs show my hover throttle point is actually 30%. i ran the calc with a 6S 6000mah pack, with correct AUW etc. - My flight time was so crazy long with the 8000 pack I decided to buy some 6600 packs :D
        3702721524?profile=original
        • Leonard- I found your excellent post here and it provided good explanation. https://github.com/diydrones/ardupilot/issues/1261 ;
          I see that this is all a more advanced method of "TPA".  If you have any suggestions on settings please let me know. I'm thinking with my large 1755 rctimer props I need 0.8 for MOT_THST_EXPO?
