Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          • Thank's to clarificate Randy, so, if software don't switch to the other compass in flight, What's the reason to have two compasses?
              The backup is only used pre-arming as a consistency check to ensure the external compass is oriented properly.  Also there's no easy way to physically remove an internal compass so because it's there we might as well take data from it.
              • Thank's Randy to clarify, In other way, is interesting to have the int compass chance, It's help me to fly until I recive the ext one and looks usefull in airplanes too; I have the gps near the motor (skywalker)
                  Cala,
                  It's not clear that switching to the internal compass would help and it's likely on some vehicle it would make things worse.  The gyros drift but the drift is quite slow so even without the internal compass, the heading could remain fairly accurate (i.e. within 30 degrees) for a minute or longer.
                  •  thank's for comment, now I know that isn't only my problem, (worse with simple mode) , I'm only flying near me now, to tune, check all things, etc. (...anxious) because I notice that, this week I have to pick up my new gps-ext compass and perhaps it's better to disable the int one.
                    PD: But I notice too, that this issue is much less with the pix and 3.3 than the 3.21 and APM
        • I understand that if you have both compasses with 1, the controller uses the ext one to navigate, if ext stop working or disconnect, the pix switch to the int one automatically but, if you have the two enable, the controller check if both readings are consistent, if not, gives an inconsistent err; perhaps, if you have int compass interferences it's better to disable int one? I'm waiting an ext one to try, if you do it after, please share your results :)
          (please tell me if my understand is incorrect)
          • Yes that makes sense thanks Cala!
      • Oh I got it wrong then. I thought that *_use was for internal and *_use2 to external.
        Thanks Randy for clarifying it
    • That's a common question I wish that was in here http://copter.ardupilot.com/wiki/common-compass-setup-advanced/
  • This reply was deleted.
    • Thanks!!!! I will give this a try.
