Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • It's the ESC flash. Lots of peeps are reporting serious vibs on 4.1x.
      Go Here and Here to read up on the issue and see what people have done to use the proper settings to get rid of the vibs [warning, fairly long threads, but worth the reading]
  • The one issue I had after 3.3 today was 'compasses inconsistent'. I wonder if I should disable the internal and this warning would go away? It flew fantastic though :D
  • Sorry if this has been asked before but it's confusing me...
    With an external compass attached, the compass_use and compass_use2 should be set to what ?
    From my understanding compass_use is for internal and compass_use2 is for external, so this should be set to 1 on both ?
      Manuel, Richard,
      So compass_use is actually for the external, compass_use2 is for the internal.  They should both be "1" unless you find the "compass inconsistent" message coming up a lot in which case you can disable the internal one by setting compass-use2 to "0"
      • hi, is it possible to connect a brushless gimbal (not servo!) to my APM?
        thanks for any help.
      • Thanks Randy. Just to clarify one other thing please. If you do not have an external connected does compass_use become the internal or is compass-use2 always the internal?
        Does the code average both or always disregard one of them? Does it have compass failover yet?
          Just a slight clarification...
          The "enumeration" of the compasses is decided when the board is powered up.  So if there's only an internal compass on the board, that will become compass #0.  If you plug in an external compass and reboot it, the external one will become compass #0 and the internal one is shifted to compass #1.  The compasses are generally used from the lowest number first so external will be used by default but you can affect that prioritisation by changing the compass-primary or the compass_useX parameters.
          The software never switches over to a backup compass in flight.  This behaviour was chosen because we didn't think the backup compasses could be trusted most of the time.
          • Thank's to clarificate Randy, so, if software don't switch to the other compass in flight, What's the reason to have two compasses?
              The backup is only used pre-arming as a consistency check to ensure the external compass is oriented properly.  Also there's no easy way to physically remove an internal compass so because it's there we might as well take data from it.
              • Thank's Randy to clarify, In other way, is interesting to have the int compass chance, It's help me to fly until I recive the ext one and looks usefull in airplanes too; I have the gps near the motor (skywalker)
Aug 25
