Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
It will be nice once the Wiki catches up on all these changes. Just a shot in the dark here but what is your MOT_THST_MAX set at? Mine is 0.95.
When upgrading from 3.3.1 to 3.3.2, is it necessary to recalibrate the accelerometers and compass or are the previous calibrations maintained?
Thank you
Michael
I didn't do it.
Thank yo for your reply Cala
I make a little test because of high wind today.
To reproduce the issue on my copter I take off in stab, , switch to pos hold, land, switch to stab, take off again in stab, try to hover in stab, switch to pos hold (there I loose altitude after update) and now works well, if the copter was climbing in stab and switch to pos hold, after update, there, he didn't do the issue. Thank's Randy to solve, tomorrow better forecast I try again larger time.
I loaded up 3.3.2-rc2 on my QAV250 and flew a little in stab, poshold and althold in pretty windy conditions. All seemed well. Switching from stab to poshold and back again at hover throttle didn't result in any noticeable drop - seemed to work just fine. Wind holding was ok, somehwat limited by the accuraccy of my GPS. So thumbs-up from me.
Just an update. Seeing lots of "accelerometers not healthy" errors. Used to get these occasionally now all the time. If I set INS_USE1=0 does that stop the pre-arm checks on the 2nd IMU?
Also what's going on here? Logs attached. clip0/clip1 have step changes. What would explain this? Are these values cumulative now?
104.BIN
106.BIN
if you are getting a lot of clipping then your vibs are too high and a lot of people are reporting it is because the bells on their motors have too much slop and removing the slop has worked wonders for them. I had the same issue on a hex with brand new motors. I've since sold off that hex and built a T960 and it no longer has the issue with the same flight controller :) Seems extreme lol but I was going to sell it anyway. The new frame and AVmount producrs nearly 0 vibs and 0 clipping.
No its not that. Here is a log from earlier, same copter, earlier FW. Vibes are about the same, but zero clip.
And clip doesn't go up and stay there - look at the graph you will see what I mean. Something strange going on.
72.BIN
