Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • Thank you very much for your reply!
        Your analysis really help (=
        I have solved the problem: one of the motors was a little inclined. I didn't noticed at a first look!
        Thank you again (=
  • Hello Everyone (=
    Actually I have a YAW problem with my big exacopter. Is a Kongcopter X6. I have a problem on the take off and also during the flight.
    I tend to YAW on itself. Is like toilet bowling but is more moderate.
    I can not understand if it is Magnetometer fault. But to my eyes, after rewieving a log it seems not.
    Attached the log.
    Can anyone help me?
    Thank you to everyone!
  • T3
    Hey quick question.  On one of the vehicles I work with, I see severe "bouncing" in auto-land due to prop wash messing with the baro.  Moving the baro isn't really an option.  Would adding a sonar or lidarlite sensor eliminate this behavior?  Am I correct in thinking that a sensor like this would eliminate the perceived swings in vertical velocity seen by the baro by providing a more true altitude?  Thanks.
    • Cover your baro with dense foam to block from prop wash and light.
      • T3
        Thank you, but I know this.  FC is Pixhawk, baro error is due to high pressure under vehicle when landing.  It is a large vehicle.
          Stephen,
          I'm afraid the sonar wouldn't help during auto landings.  It's because the sonar isn't used in AUTO or RTL, it's only used in more manual modes like AltHold, Loiter, PosHold.  It might seem at first that it should be easy to use in Auto, RTL, etc but it gets a bit tricky when we start mixing relative-to-home and relative-to-terrain altitudes.
          The Solo suffers badly from the baro effect so we've accepted a change from the Solo devs that addresses this and means it could be included in Copter-3.4.  We would need to do a bit of additional work to allow that feature to be turned on/off (new issue raised here).
          • Randy, would Lidar/Sonar work in Guided Mode?
  • We finally got decent weather here in Scotland today, so took my new carbon 330mm quad build out to run an autotune. Sadly, the autotune results were pretty dreadful - (with AUTOTUNE_AGGR set to 0.065) I only did the autotune on the roll axis, and this resulted in very low P/I values, ending in almost uncontrollable roll response. The dataflash log is attached for anyone who has eaten enough turkey and got bored with this Christmas malarkey already ;-)
    Afterwards, I set the PIDs all back to defaults, and also set the ATC_ACCEL_R_MAX value back to 108000 (suggested Medium setting - set the same for pitch) as this was set by autotune to a really low value. I noticed that ATC_RATE_FF_ENAB was set to 1 (this is likely due to the fact that I ran this FC in a different frame previously and ran autotune on that frame also). Should I have set this value back to 0 before running the Autotune perhaps? Would have this set things up to provide better initial settings for AT to have a better chance at success?
    I then went for some manual tuning and ended up with values completely at the opposite end of the scale which feel far more responsive - not completely locked in yet as I only had two LiPos so ran out too soon to complete the manual tuning. I ended up with manually set values:
    • Rate (Roll and Pitch) P at 0.25
    • Rate (Roll and Pitch) D at 0.004
    • and Stab P at 6.0
    I haven't tuned the I gains yet - still set to defaults
    The spec of the quad:
    • Turnigy Talon v2 frame, cut down to 330mm
    • AUAV-X2 running APM:Copter 3.3.2 Quad
    • Ublox Neo-7M GPS/mag on pole
    • Sunnysky v2814-9 870kv motors
    • 8045 carbon/nylon mix Gemfan props
    • X-rotor 20A ESCs
    • Turnigy A-Spec 2600mAh 65c Lipo
    • 415MHz APM telem radio
    • FrSky X4R-sb Rx with FLVSS LiPo monitor
    • Teensy 3.2 running Clooney82 Mavlink-FrSky telem conversion
    • AUW: 1325g
    I'm willing to give AT another try if someone will kindly tell me what initial settings they think I should make for say:  AUTOTUNE_AGGR, ATC_ACCEL_R_MAX, ATC_ACCEL_P_MAX,ATC_RATE_FF_ENAB, plus suggested starter PIDs.
    Thanks and best wishes, Paul
    2015-12-27 19-21-30 24.bin
  • I'm having an issue that the hexacopter just shoots randomly into the sky without me applying any throttle on it since on firmware 3.3.2. This happend two times towards the end of the flight and I tried to land it because of this. When landed the drone spiked in throttle one last time and shot into the air. Really scary.
    When looking at the log it might look as if I apply the throttle myself, but I promise that the last peak is not self-inflicted.(the other two peaks I'm not sure how to distinguish them from the others).
    5.BIN
  • Bad days are coming....another multirotor failure....this time everyone will see it,world ski cup,no.1 skier escape for inches... https://www.youtube.com/watch?v=MvF49R_ZX5E ....what could go wrong?Marco Robustini,its in your country,do you know something about it?
