Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • I also use M8N from Drotek. I had to close a slolder bridge to switch it to 3.3V signal level. Did you change the configuration of the M8N according to the Pixhawk´s requirements?
        It looks like your GPS uses SBAS (GPS-Status 4). I would recommend to switch it off because it causes jumps in position when it switches to/from corrected mode.
        • Hi Hubertus  I have soldered the 3.3v bridge and i have tried three Drotek GPS units ..The SBAS thing is interesting as the Gps is supposed to be flashed with the correct config code when the pixhawk boots up. Even Randy has said in the past the config is sent by the Pixhawk so no need to do it manually ..Maybe i have a problem and its not doing it automatically, what test can i do to make sure its getting set by the pixhawk, can check baud rate and other settings by looking in MP while it all powered up ?
          • copter.ardupilot.com/wiki/common-ublox-gps/ shows how to go through pixhawk with ublox.
            Connection Option #1 – Mission Planner and Pixhawk as Passthrough
            So you can verify the default settings of your gps connecting directly with ublox and after that compare to the settings sent by pixhawk when you connect ublox trough pixhawk to gps unit
            • Hi Paul ..thanks .. I can do the Ublox thing ok, used to do it all the time with the old 6n units but only direct connection using ftdi unit not using MP (But have not done it with any M8Ns, I was not aware there was specific new config file for the 8,  I would like to Check the config in MP while GPS is running I know there is a comprehensive status messages you can look at ..i just have to find the right lines .. and which line tells me what info ... i guess i am looking for baud rate of 38400 and UBX ? these are the two main ones ..or others to check on...Also how to switch off SBAS?  cheers
              • Reuben, when you go trough MP you will still use ublox, so you can see the difference in settings between default settings of of the gps (when using ftdi) and settings of the gps as instructed by pixhawk. You still use the ublox programm interface.
                • Ok I tried to connect through MP .. but could not .. when pressing Mav serial Pass not much happens press it a 2nd time MP freezes.. I did open U center  and tried to set the port and TCP but the Network button did nothing "no additional menu to set port"  etc...i was using V8.01 ..so upgraded to 8.18 it did have some Tcp settings but still no luck .. finally i used the old FTDI cable .. seems it was default at 9600 baud I loaded M8 txt config file .. and checked sbas was disabled in the config screen. I also fould an sbas disable setting in MP params ..so did that to . I also made a small emi shield ..and retested ..it was better but still got Horiz error and Velocity error once or twice .. I finally fitted a Neo 7M unit and redid compass calib and flew again ..better no errors just compass bar got a little high now and again
  • OK Guys
    I am panicking!!... Have an Air show to do in 24 hrs ..at the airport and I have just replaced my trusty APM 2.5 to Pixhawk running a Dropix M8n + compass  loading 3.3.2 and have been out flying after doing all Calibs .. now what happens is some times the copter will just take off in an unauthorized direction and in Auto mode does not follow the plan well and can shoot off to other location ..seems to be EKF errors but I am new to this and the logs now have some much info its mid boggling ...my vibes seem good as when i was flying i was watching the two monitoers on MP (vibe and EKF) all the scale bars hardly move!! .. can someone Randy :)  maybe,or any other helpful sole take a look at the log ? which is better Tlog or BIN?  Thanks guys  really worried now about flying in a public event.
    Thank Thankyou !!
    8.BIN
    2016-01-21 13-49-28.tlog
    • Hi Guys ... I have just seen there is a EKF Horiz Varinance error and Velocity bar goes up a bit too high ..
      I did wait quite a while Sats and sensors to settle you can see the time slot in the replay of the Tlog .. i dont think i was too low as we fly loads of missions at low Altitude the Apm never gave trouble with the same airframe, yes I agree it is a little under powered but has been like this for 3 years. It it wise to disable on board compass?
      Cheers Guys
      • You are comparing apples to oranges. APM != Pixhawk. They may run the same firmware but that is pretty much where the similarity ends. You are also comparing 3.2.1 with 3.3.2 firmware which again is a VERY different beast. You basically took out an old 4 cylinder engine with an 8 bit computer control and replaced it with a new 8 cylinder engine with a 32 bit computer control and are trying to say that it should run the exact same as the old engine because the chassis and body are still the same.
        • Hi Craig
          Yes I have have put a cleverer brain into the same chassis .. and the chassis is good, vibes low ..yes a bit under-powered but flown over 140 missions .. but why misbehave so much now?..is it compass or bad Gps ? I do have the same machine running pixhawk and Dropix M8n but that machine only differs by having a little bit more power and running 3.2. and that machine has done also over 100 sorties no issues.
          Also a side note, the Dumber controller APM 2.5 had no trouble controlling the same chassis .. I was expecting a better result with the smarter faster controller. I know firmware is very different but much better ! So should have no issue ..But it has .. and what is it ??? the the million doller question :)
          needlless to say I am pulling my hair out .. time is running short for me.
          Thanks for your help so far.
