Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          • re-We're going to be setting up a donate button on ardupilot.com in the near-ish future.
            GREAT!!!!!  It's not unreasonable at all not to mention it's voluntary.
            Is the a repository to download dated versions of 3.4? I installed that in December and have had zero problems. I'd like it install it in Pixraxer. Is there some way to tell what version / date installed I have now? I know in the message page it says what version is booted up and a few numbers after that are those numbers a reference to that? Then again.. I know there were a few minor glitches you worked out for copter code for pixracer... guess that wouldn't be in a dated 3.4 if in 3.4 at all? 3.4 has boat mode... something I definitely need.
            Thanks Randy!!!! I wish I could help out with code but I'm just a carpenter! LOL
      • That nice Randy, It's possibe, until you found sponsors to have a "DONATE" account to send a little amount of money everybody that's download the new vers? I think, with 70.000 members, many  have two or tree boards, a little esford that anyone here do, if everybody do, I hope you can sort this transition with less troubles; you and team always helps Us, now time to Us to help a little. ;-)
      • @Randy, I thought you are in the safe zone, Sigh:-(
        The key is successful introduction of Pixhawk2 that is the key to new ArduPilot eco system.
    • it's amazing how active chris anderson in the news reports is.
      I think the slower are the developments that sales of 3DR is also slow,
      My thanks to all developers for this wonderful project.
      All developers have helped so 3DR has grown.
    • just had a look here: https://github.com/diydrones/ardupilot/milestones
      The AC 3.4.0 milestone is only 27% complete. I guess now that a lot of developers have had their support withdrawn by 3DR the dev speed might be slowed down a lot. I'm not sure really what's going on. In the end it is an open source project and therefore has no real 'deadlines' to meet.
      It is a shame, though. I was eagerly awaiting the EKF2 and boat take off. I tried flying master under controlled conditions and it worked great. But I'm too scared to fly master in the wide open.
      • 27% ? I had no idea it was that far behind and was really looking forward to integrating some of the neat stuff in my copters this year, but without dev support it won't happen. Things like collision avoidance, advanced Lidar, boat launching etc.
        If there was a way to support the effort, I'd gladly pay a yearly fee. It seems there was mention of providing monetary support for devs, but it wasn't clear if it was for PH1.
        I love my DIY copters, but if 3.4 doesn't materialize this summer, gulp, the P4 is looking to be a viable option. Solo is fine and is supposed to support add-on hardware, but nothing is available yet that I'm aware, plus I need more flight time.
      • I worked around taking off from a boat by arming my quadcopter on land, and keep the battery connected (it will soon disarm if not touching the throttle stick), then departure on boat. When I reach the site I want, re-arm the quadcopter. I did not use RTL, out of concern the drone might go back to where it was armed, but set the last waypoint where taking off, then land it in loiter mode.
        I was using pixhawk AC3.2
      • I've been flying 3.4 since Dec without issue. Although if anythings been done since Dec I guess the experience could be different.
  • I have a couple of issues which I can't figure out.
    1. At the field the last couple of times I have not been able to get a 3D GPS fix at all. HDOP stays at 99. Now I'm in my office and I'm getting a 3D fix inside easily, which seems crazy. The only differences are I just upgraded to 3.3.3 from 3.3.2rc, it's warmer in my office than outside (by about 20o) and I am on USB power rather than battery. can't really see how any of these would translate into GPS no workee. Any ideas? It's not a connection issue in case anyone wants to suggest that :)
    2. I have calibrated the accelerometers multiple times but I end up with a corner drooping in flight and the copter drifting a lot in AltHold. Could this be temp related? How flat does the mounting of the FC have to be relative to the frame? I would have thought that the calibration and leveling would take care of any discrepencies, but does it?
    AUAV-X2 if it matters.
    • Andy, I see similar things, were it boots up fine, but will not lock GPS until I unplug it and start over. Then it works fine. Have you tried that? As for the leveling, that is done when you arm it. Whatever angle it is when you arm is what it considers level. Calibration, it seems is affected by the temp. I was having problems with accel and magnetometer cals and it was suggested that I cal in the cold. That seems to help, though it isn't as cold out now. Hope that helps.
