Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • Here is a short overview of todays log for the 2016 version of the "FPV Hexaracer",
        (The only thing i was changing from 2015 are the motors from KV1800 to KV 2050)
        This thing is crazy fun.
        Some Facts :
        Peak Current : 180Amps
        Peak Climbrate : 23-24m/s
        Peak Speed (GPS) : 29-32m/s
        3702742702?profile=original
      • Hi Paul, i'm currently not up to date concerning all the new features, the development really brings this project to news levels. But i'm with you, the copter is very well balanced and all components have been selected and tested over years to become reliable. Now i'm there were the copter has become reliable. Somewhere in this forums the should be some pictures of the build
  • Hi I need help with my Hexa on AutoTune
    Hexa with 3.3.3 fly ok with default params no issue.
    wanted to have smooth settings and done Autotune.
    After Autotune is done and params are saved, Hexa Oscillates even on ground when arming and bit THR up.
    Tried this twise by resetting all and running another Autotune, but with same results.
    Can someone please help ?
    3702222017?profile=original
    • did u run autotune and connect with telemetry and pc when autotune ?
      • I run autotune and connect with telemetry to my phone running tower for monitoring.
        log files
        • Autotune is not the perfect tool, it depends on the wind, vibrations, type of frame, etc.
          My best experience with different frames is manual tune by tethering and in flight with the Ch6 manual tune tool.
          • It worked before with same setup on Copter 3.1
            I don't have earlier pids but will test it maybe without yaw.
            • I had a look on your log from November 26, 2015
              Is that same copter? PIDs seems OK, reacting quite well. It was overpowered at that log, powerful, but without load.
              It is not good idea to tune large platform without the weight that is designed for. Can use dummy weight.
              Last log shows huge oscillations, caused by wrong PIDs. The autotune gives bad results, probably due to the overpowered copter  - average ThrOut is 350.
              Can you advice what is the frame, details, photos?
              • I can propose to test the following parameters:
                Stabilize Roll 8, Stabilize Pitch 6, Stabilize Yaw 4.5
                Keep the Rate Roll and Pitch PIDs from the last autotune.
                Put Rate Roll/Pitch both Imax 1000,
                Rate Yaw P 0.2; I 0.02; D 0
                • Thanks for your help.
                  Had crazy week, but did some testings today.
                  Lowered settings and i'm now vibrations are gone.
                  still need to retune the system to better stabilization.
